Old 01-27-2013, 10:24 PM   #1
chad64chevy
chad64chevy's Avatar
firewall insultion pad and carpet pics please!!
was wondering if anyone had installed the fiberboard/cardboard insultion pad and have carpet in there trucks! if you have any pics that would be great! i'm trying to get an idea of where the carpet would met on the insultion pad! like if it would overlap the pad or not! if it doesnt then i need to order a yrd. of carpet! anys pics of the floor where these two pieces met would be great and help as a guide!! thanks for any input
chad64chevy is offline   Reply With Quote
Old 01-28-2013, 03:44 AM   #2
kerber63
kerber63's Avatar
Re: firewall insultion pad and carpet pics please!!
Here are a couple pics, sorry they're not the greatest. You can kind of get the idea. The carpet does cover the bottom lip of the cardboard firewall pads, and it's got a finished edge so it looks good too. I can take better pictures in a few days if no one else has some.
kerber63 is offline   Reply With Quote
Old 01-28-2013, 03:52 AM   #3
DesertCat
DesertCat's Avatar
Insultion? Firewall insultion? Don't do it! You never want to insult your firewall!
Of course I know you meant insulation, just couldn't help myself... as usual
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 01-28-2013, 07:18 AM   #4
MikeS.
MikeS.'s Avatar
LOL.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 01-28-2013, 08:18 PM   #5
chad64chevy
thanks kerber63, if you wouldnt mind showing some other pics that would be great!! and where did you get your carpet from?? it looks good in your truck!!
thanks desertcat, i just realized i was miss spelling insulation! but anyways ya'll know what i mean, lol!!! maybe thats why not a lot of people have chimed in!
Old 01-28-2013, 09:23 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Bed liner on underside of floor panels+peel N stick on the inside (2 layers in some areas)..+insulated/reflective pad on firewall+ carpet and carpeted back wall.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-28-2013, 10:24 PM   #7
kerber63
kerber63's Avatar
No problem, I'll take some better pictures this weekend. Anything else you'd like to see? Carpet, firewall pad, and double sided heatshield below the carpet all came from The Truck Shop.
Old 02-02-2013, 06:56 PM   #8
kerber63
kerber63's Avatar
As promised, here are better pics. The closest the edge of the carpet came to the edge of the firewall was over the low hump, about 1" overlap.
Old 02-02-2013, 09:42 PM   #9
chad64chevy
thanks kerber, those are the pics i was needing! your trucks interior looks great, nice job!!
Old 02-02-2013, 10:51 PM   #10
WhippinSaw
WhippinSaw's Avatar
I put 4 coats of wet paint on a repro firewall cover. Came out better than I thought it would
WhippinSaw is offline   Reply With Quote
Old 02-03-2013, 12:59 AM   #11
kerber63
kerber63's Avatar
Thanks! Good luck with your interior. FYI I bought a yard of carpet from an internet site to cover a speaker box behind my buckets and it matched my molded carpet color perfectly.
Old 02-03-2013, 02:19 PM   #12
LDO
LDO's Avatar
Kerber, any more info on how you made that rear speaker enclosure in the last pic?
LDO is offline   Reply With Quote
Old 02-03-2013, 04:21 PM   #13
63sbssbbw
UCA63
63sbssbbw's Avatar
That's just funny right there ..
I didn't even notice that when I opened the thread
But it contained everything that I thought it would.
LOL .. from a guy that laughs at internet ad misspellings.
BTW ,nice interiors.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 02-03-2013, 06:03 PM   #14
kerber63
kerber63's Avatar
Thumbs up Re: firewall insultion pad and carpet pics please!!
Sorry, I didn't take any pictures during the build, wish I had. I built 3 mdf boxes - 1 behind each seat going from the recess in the cab corner to the outside of the driveline hump, 1 over the hump, all screwed together after install. The fronts angle from just in front of the old fuel tank mounts to the back of the cab below the window. The corners angle back to clear the door frames. All 3 boxes are bolted through the floor. The carpet has a little adhesive sprayed in the flat parts, the top and bottom are tucked around the box edges. The sub has a 1" spacer for clearance. The whole thing went together pretty easy.
Old 02-03-2013, 06:27 PM   #15
LDO
LDO's Avatar
C'mon man! You know you're supposed to picture and document EVERYTHING!!!
just kidding, I'm guilty of it myself. If the wife doesn't come out to take pictures, I won't have any pics myself!
Old 02-04-2013, 02:14 AM   #16
likaroc13
Rollin' Old Skool
I know you already saw what you needed to, but here's mine as a reference for the thread:
[IMG][/IMG]
[IMG][/IMG]
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
