Old 01-27-2013, 11:19 PM   #1
McKenna
Frame mounts
Hey again guys, need some more advise as always! Some day maybe I can do the same.
I'm in the middle of trying to finish my frame befor I bolt all my new parts on it paint etc.
I never noticed now until I got my cab off but someone has attempted to fix the 4 cab mounts on the frame, and have done a poor job at doing so.
One is actually visibly higher then the other and after seeing the hockey puck mounts it is questionable wether any of my gaps would line up properly, I could probably fix them had someone else not been there befor me to f**k them. Seems to be the story behind everything on this truck.
Does anyone make these mounts ? I could just grind my rivits off and bolt new ones on? Or am I better off to upgrade my membership and list a wtb ad for a good set of OEM.
I really don't have the time to make a set or measurements to go off
Of
McKenna is offline   Reply With Quote
Old 01-27-2013, 11:23 PM   #2
YBNORML
YBNORML's Avatar
Re: Frame mounts
If I recall correctly, Early Classics sells a cab mount kit. You could try their website.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-27-2013, 11:43 PM   #3
YBNORML
YBNORML's Avatar
Re: Frame mounts
I just checked their website and went through their catalogue, I couldn't find them. I'm sure I've seen them reproduced somewhere. If you want used ones, there are a few guys who are constantly parting out trucks. One them could probably help you out. Just check the parts board.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-28-2013, 12:11 AM   #4
McKenna
Re: Frame mounts
Thanks, I looked too with no luck LMC also doesn't have them listed
Old 01-28-2013, 12:51 AM   #5
KrazyRay
KrazyRay's Avatar
Re: Frame mounts
I have some solid OEM cab mounts if you can't find new ones. I can post a for sale thread on the parts board.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 01-28-2013, 12:57 AM   #6
dfwright
dfwright's Avatar
Re: Frame mounts
Brothers has some:
67-72 Cab Support Frame Mount - Rear - Pair
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
