Welding the Backing Plates
The backing plates on my Dana 60 have grooves cut into them where the edge of the brake shoe rides. Can I weld this up and grind flat or should I replace them?
If replace, where can I get them? I have tried LMC and other popular after market maybe I just missed it. Also what brake hardware kits fit 67 GMC 3/4 ton with leaf. I only see 67 3/4 ton with coil on LMC. Ive already ordered wheel cyclinders only to receive the wrong ones cant afford to keep working this way. Thanks!!! |
1969 Custom 30 wrecker
Re: Welding the Backing Plates
I see no reason why you couldn't weld and grind smooth. Would be alot easier than removing and reinstalling others.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
My Carbon Footprint
Are you sure that is where the shoe would normally ride? Wondering is something was hung up in there. Doesn't seem like the shoe should run on that edge anyway. Hard to say without being there. If it's just an old work truck, I'd just throw on some new shoes and move on.
I don't see any reason not to weld it up.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
If you have a welder handy go for it...Specs actually call for a spot of grease on those locations to ease brake operation and reduce wear...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I've welded these grooves on my chevelle and el camino. and every thing smoothed up in the braking dept. mine were so deep you could hear the shoes click as they jumped over them.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
![]() Join Date: Mar 2003
I do it all the time..........weld away
Prostreet- Yes that is the pads where the metal edge of the shoe rides. Both were sitting in these grooves when I pulled the drum.
These are pretty deep. I will weld them up then. Thanks for the help!!!! |
