01-27-2013, 11:36 PM | #1 |
1968 GMC 3/4 Ton 4x4 lwb step side?
Hey guys I am brand new to the forum, and also new to these trucks. I have a 1968 GMC 3/4 Ton 4x4 long bed step side that i just bought from my girlfriends dad. I have had a very hard time finding info on this truck as it seems that this veriation is not too common. Is this a rare truck?
01-28-2013, 02:13 AM | #2 |
Re: 1968 GMC 3/4 Ton 4x4 lwb step side?
With that name I'd expect you to be more of a Range Rover classic owner (not a bad thing :-) ), but to answer your question the 3/4 4x4 stepside were a fairly low production vehicle and usually commercial use trucks. Not sure where you can find actual GMC production numbers for it but Chevy the same year was about 1047 for the '68 K20 stepside.
Welcome to the board!
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
01-28-2013, 02:18 AM | #3 |
Welcome to the forum! The long bed step sides I believe have the 8 1/2' bed like the Longhorns. Which I think actually have 1 ton suspensions. I'm pretty sure none of them are 4X4. I don't recall ever seeing a longbed stepside 3/4 ton 4X4, but I'm not sure. The long bed step sides and Longhorns are not exactly "rare" but there but there are less of them. Surely someone more knowledgeable than me will chime in. You should post some pictures.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
01-28-2013, 02:55 AM | #4 | |
K2500 GMC trucks 4x4 3/4 ton were built on a 127" wheelbase. It was offered in Chassis Cab, Wideside and Fenderside versions. As you mentioned there were other bed sizes but not on a K2500. The 8 1/2' bed was a Wideside only offering on a 1 ton chassis with a 133" wb as a 4x2 only in C2500 or C3000 ratings. There was a 9' Fenderside C3500 as well, again 4x2 only. Historically the 3/4 4x4 stepside/fenderside trucks were low production commercial use trucks and as I stated above Chevy built 1047 in '68 and since GMC number are usually lower it might very well be below 1000 units.
01-28-2013, 03:14 AM | #5 |
Here are some pictures of a very nice GMC K2500 Wideside.
01-28-2013, 06:38 AM | #6 |
Never seen one of those. Is that the stock ride height? I like the looks of it alot.
1972 Custom 10 Deluxe- original paint, interior- 72k miles http://www.cardomain.com/ride/2466316 Cheap, Fast or Good. Pick any two. 1990 Eagle Talon AWD 1991.5 W250 CTD 1992 Cushman Truckster- Haulster |
01-28-2013, 06:41 AM | #7 |
nice!!
01-28-2013, 08:09 AM | #8 |
Tim meant to say that's a Fenderside,the GMC equivalent to Stepside.
01-28-2013, 10:26 AM | #9 |
Thank you guys for the information so far. I am working on the pictures and will have them up shortly. The bed on this truck doesn't have the spare tire cutout on the drivers side. It has the wooden bed (although it is in need of replacement), clearance lights (chicken lights), and is sitting on 6" of lift. Hope this might help to sort some questions out.
01-28-2013, 11:28 AM | #10 |
Thanks for catching that Tim, can someone edit that in post #5?
01-28-2013, 03:33 PM | #11 |
My truck has the rockwell transmission and transfercase and i can't get the linkage to move the low range piston (sorry if that isn't the correct term). Is there a simple sollution to this issue or do in need to drop it out and overhaul the linkage. I can pull that piston, but only with the help of a prybar.
01-28-2013, 04:12 PM | #12 |
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
01-28-2013, 04:13 PM | #13 |
Sounds like you are going inside and parts can be an issue.
Here is the exploded view. If you don't have the service and overhaul manuals they can be downloaded here. http://67-72chevytrucks.com/vboard/s...d.php?t=558016 If you have to pry on the linkage and it will not reverse there is likely a fork isssue or interlock. Dropping the trans and pulling the cover should give a quick idea on what the damage is and what parts are needed. Unfortunatelly it also leaves your truck stranded. Might start a search to see if there is a spare about to do a temporary exchange. Starting a seperate thread like "T221 Help needed" in the 4x4 section might get more/better results after trying a site search.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 01-28-2013 at 04:25 PM. Reason: add image |
01-28-2013, 04:14 PM | #14 |
Thanks for the info!
02-06-2013, 12:48 AM | #15 |
Not the best pictures in the world, but here she is!
02-06-2013, 01:47 AM | #16 |
Very cool truck. Welcome to the board.
Doug '72 GMC K2500 Suburban 4x4 |
02-06-2013, 02:39 AM | #17 |
Very nice , got to love the long steps .
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
02-06-2013, 02:42 AM | #18 |
Nice! So all that side trim didn't continue onto the fender-sides, I'm guessin'.
MusicMan70 1961 GMC Suburban |
02-06-2013, 02:46 AM | #19 |
Very nice, now how about a SPID or at least some specifics. Any luck with the t-case issue? By chance were you trying to shift it static with the engine off?
02-06-2013, 03:09 AM | #20 | |
Here is a '67 9'CST
02-06-2013, 06:30 AM | #21 |
02-06-2013, 06:00 PM | #22 |
Currently Blazerless
Love it! I wouldn't change a thing on that beast... Perfect color and patina
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
02-06-2013, 06:14 PM | #23 |
02-06-2013, 08:13 PM | #24 |
Great looking truck!!! Love the color (but I may be partial).
02-06-2013, 08:35 PM | #25 |
That truck is about as cool as it can be, I wouldn't change a thing.
From the slots to the stance and perfect patina, I would drive the wheels off that thing. Thanks to SSTim I learn something new, never knew '67'68 stepsides could be had with trim. |
