01-27-2013, 11:40 PM | #1 |
Panhard bar and sitting level?
This question may be completely off the wall, but figured I would ask anyways. After lowering my truck last year the drivers side seems to sit down further than passenger side. It did before, but is more noticeable now. Would installing an adjustable or super track bar kit help to even this out?
Just a thought since the bar would be pushing from opposite sides of the truck? Thanks all! |
01-28-2013, 01:36 AM | #2 |
Re: Panhard bar and sitting level?
It could be pulling it over. Undo one end of panhard bar and see.
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
01-28-2013, 06:06 AM | #3 |
old used chevy pickups twist thier frames and it is not at all unusual for the driver side to sit lower than passenger side// has nothing to do with panhard bar
01-28-2013, 08:56 AM | #4 |
I agree. Very doubtful the bar caused this. More likely a spring or leaf weak on one side or as mentioned a frame twisted. The bar should only center the tire in the wheel well fore n aft. At least that is how I see it.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
01-28-2013, 09:05 AM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Check those springs in the front...Are they original? Also, take a look at the cab supports, are the all there and symmetrical? My 72 was 1" lower on the left...When I replaced the stock springs with drop springs I discovered 1/2 coil was busted off the bottom where you cant even see it...truck sits nice and level now.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-28-2013, 09:06 AM | #6 |
Quit if it's not FUN!!!
Welcome to the "Truck Lean" . I thing most of these old trucks sit unlevel. After I put 4" drop springs in my stepper I had to add a (homemade) 1" lowering block on the right side to get it level.
01-28-2013, 09:19 AM | #7 |
I agree, .. Normal Chevy Lean. 95% of the trucks I have ever lowered have this problem. It's just more noticeable once it's lowered.
The problem is the driver's front coil spring. You can put a spacer in the front spring (Summit sells them actually) to bring the DS front UP about .5 - .75 in .. or like some do with the lowering block in the rear. Personally I'd do the spacer up front. .. OR cut 1/4 coil off the pass front spring (?) Would do about the same thing.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
01-28-2013, 10:49 AM | #8 |
Even my frame off with new suspension leans a little.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
01-28-2013, 12:07 PM | #9 |
Had to make a 1/2 inch plate for the upper left rear spring mount to fix mine. has new springs all around. Found this out by measuring the spring height with all four tires on the ground left rear was 1/2 inch off. also tried another set of springs [new] and still 1/2 inch off
Fuzzy |
01-28-2013, 12:48 PM | #10 | |
01-28-2013, 12:51 PM | #11 | |
01-28-2013, 12:52 PM | #12 |
Thanks to everyone for the help and suggestions so far!
01-28-2013, 12:56 PM | #13 |
Assuming you have the lower lip on the spring indexed into the lca properly (? ) probably something you have checked already.
I have heard the frames were built with 1/2 lower on the DS to accommodate the twist from the engine torque. Kinda goofy really IMO. Posted via Mobile Device
01-28-2013, 01:36 PM | #14 | |
01-28-2013, 01:52 PM | #15 |
Florida Edition
Took me a few shots at getting the front springs to seat properly in the upper a-arm after cutting 1/2 a coil off, pretty tricky.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-28-2013, 01:53 PM | #16 |
Florida Edition
And you need the adj bar too........
01-28-2013, 02:05 PM | #17 |
01-28-2013, 03:05 PM | #18 |
How much is it off?
01-28-2013, 03:21 PM | #19 |
Hire a fat girl to ride around with you?
01-28-2013, 03:24 PM | #20 |
I would have to take measurements of the wheel well to tire on either side, but if I were to guess maybe an inch or so??
Don't know if the difference is that obvious from this picture Last edited by Olive1970; 01-28-2013 at 03:30 PM. Reason: added picture |
01-28-2013, 03:33 PM | #21 |
01-28-2013, 03:35 PM | #22 |
01-28-2013, 03:35 PM | #23 |
In Addition to measuring the wheel wells, measure from the frame to the ground.
01-28-2013, 05:04 PM | #24 |
Florida Edition
Did you put a rear shock relocator kit in it?
01-28-2013, 05:40 PM | #25 |
I did not, the springs are only a 3" drop in the back. Or at least thats what they were listed as. It didnt seem the kit was necessary for that drop according to CPP or ECE.
