01-28-2013, 01:11 AM | #1 |
Motor mounts
Installing a big block in 66 having a hard time finding motor mounts and headers any ideas.
01-28-2013, 01:44 AM | #2 |
60-66 Nut
Re: Motor mounts
Welcome to the forum
For motor mounts you can use either the '68-'71 big block motor mounts and brackets, or the '73-'87 C20/30 motor mounts and brackets. For headers, you can use either the '68-'72 pickup headers, or the '73-'87 pickup headers. Both of those are long tubes and do hang down a ways. Some guys have had luck using Chevelle headers. I believe there are some other shorter ones, but I don't have specific info handy. You might check out some of the build threads where a big block was installed. Members 66Farmer and 198plus, both have installed big blocks
01-29-2013, 02:23 AM | #3 |
Re: Motor mounts
Thanks for the info,I will follow up on this.
