Old 01-28-2013, 10:57 AM   #1
Jon01
Jon01's Avatar
71 350 Carb to pan, all accessories, 3 speed trans
I'm selling the 350 out of my 71 C10 to make room for the LM7.
It is a good running fairly fresh motor, has about 20k on rebuild.
Has an Edelbrock intake and an RV cam.
Will be sold complete, Q-jet to pan with all accessories - p/s, alt and a/c compressor with all brackets.
I believe it is the original motor out of the truck, block # is 3970010.
It is still running in the truck so you can see/hear it run at any time and drive if you'd like. Trans shifts good and clutch is strong. I can include the TOT column if that would help as well.
I will not pull it until a deposit is received. I can ship but there will be added cost, I would rather meet someone locally or within a reasonable distance of Des Moines, Iowa.
$575 for everything. This is perfect for someone putting a truck back together that's missing the drivetrain as you won't have to hunt up any of the little parts.
I would do some trading for lowering parts - springs, spindles, etc...
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 01-28-2013, 04:47 PM   #2
brian1971
brian1971's Avatar
Re: 71 350 Carb to pan, all accessories, 3 speed trans
Man I wish you were closer,are you heading east any time.Don't need it anytime soon but i'd like to get it for my 71.Ill send you a pm thanks Brian.
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 01-28-2013, 09:12 PM   #3
Jon01
Jon01's Avatar
Took a deposit on it tonight, gonna call this sale pending.
If it falls thru I will drop you a line Brian. I've shipped motors out west for a couple hundred bucks.
Old 01-28-2013, 09:39 PM   #4
brian1971
brian1971's Avatar
Ok thanks,keep me in mind if you don't sell it.
