Old 01-28-2013, 11:27 AM   #1
1967gm4x4
67 gmc
I am having a hard time finding this type of fabric for my 67 gmc, all i can find are the vinyls. I called a few upholstery shops and they have no clue. Also from 67-72 was there a heavy duty 3/4 ton and a light duty 3/4 ton? I know there was in the 73-87. I was looking at a 72 1 ton and every thing looked the same as mine even the suspension.
1967 gmc 4x4 factory air factory buckets
1985 gmc high sierra 2500 4x4 400 1972 ford f250 4x4 390.Tomorrow is the most important thing in life. Comes into us very clean. It's perfect when it arrives and puts itself in our hands. It hopes we've learned something from yesterday. John Wayne
1967gm4x4 is offline   Reply With Quote
Old 01-28-2013, 06:17 PM   #2
etindoll
Re: 67 gmc
I work for an upholstered furniture manufacturer here in MS, and that looks like a lot of the fabrics they are using on home furniture these days. You maybe able to get a small swatch from your seat and take to a furniture repair shop in your area and they can match it up with something close.
etindoll is offline   Reply With Quote
Old 01-31-2013, 03:11 PM   #3
1967gm4x4
Re: 67 gmc
Does anybody have any info on the suspension and rear end options from then?
Old 01-31-2013, 08:10 PM   #4
Re: 67 gmc
I don't believe you can get an off the shelf lift kit for a pre-69 GM. The springs are wider. I've heard of guys using the later leafs with spacers,but I'd either go to a spring shop or a custom off road spring company,like Deaver. They can make ones that ride better,no just higher.
www.deaverspring.com
Old 01-31-2013, 08:23 PM   #5
71swb4x4
71swb4x4's Avatar
Re: 67 gmc
Are you taking a sample of the upholstery in? I assume you know it's custom right, that is not factory upholstery.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-31-2013, 09:12 PM   #6
1967gm4x4
Re: 67 gmc
I figured that was factory because it matches the door panels and even the gas tank cover. What would have been in this truck from the factory in a super custom?
Old 01-31-2013, 10:32 PM   #7
71swb4x4
71swb4x4's Avatar
Re: 67 gmc
It is definitely not factory, neither is the covering on the door panels or gas tank cover. Vinyl would be factory. I will find some pictures of factory interiors for you.
Edit: I took this from another thread, it gives you a good idea of the material and design. There are more photos here: http://67-72chevytrucks.com/vboard/s...d.php?t=515454
Old 01-31-2013, 10:59 PM   #8
1967gm4x4
Re: 67 gmc
Ok that gives me a good idea, I'm am trying to get the truck as close to factory as possible. That end the search for that upholstery, for the springs I was trying to figure out if there was a camper special in 67, I would like to leave it at stock height and get original wheels eventually, I appreciate everybody's help.
Old 01-31-2013, 11:22 PM   #9
71swb4x4
71swb4x4's Avatar
Re: 67 gmc
There is a board member here that is a great source for factory seats: http://67-72chevytrucks.com/vboard/s...d.php?t=532345
gmc 3/4 ton chevy 3500
