Ok, I’m wet behind the ears so this may seem like a silly question, but I’m a novice so bear with me.
What parts are reusable from the 98 5.7 vortec to an 84 305 v8? I plan on junking the burb soon since the trans is shoot and it now needs head or intake gaskets…the smoking has gotten the best of my humor. I’m thinking it would be worth a shot, both are small blocks but I want to be sure this is possible before I tear into it. How much difficulty am I looking at what parts will I need (besides the obvious) to take the serpentine setup and use it on the 305?Is it a direct swap?Will I swap the water pump as well?Also are any ac components interchangeable?Are the wheels from the burb compatible also? Anyone on here made the switch? As always thanks for the advice, it is greatly appreciated.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
Re: Possibly interchangeable 5.7 vortec to 305 v8...Opinions, please
just about everything but the pistons will interchange, but if you want to use the heads the intake is vortec specific, so you have to use the whole top end
Thanks!
Forgot about alternator wires on my 84 305 v8 how will that adapt to the alternator from the 98 5.7 vortec? Any other wiring I may need to rip from the 98? thanks
Could you possibly rebuild the vortec and scrap the rest? A 5.7 vortec in your truck would be a good swap
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
![]() Join Date: Jul 2010
you would have lowwwwww compression ratio if you run them as 64cc with out having them milled or changin tha pistons.. sell tha whole motor & trans & make some coin..you can use tha serp setup...water pump & tha wheels with work ..depending on if they both are 5 lug 2wd..or there both 6 lug 4wd...it's not worth tha wrench time to do tha head swap
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Sell the 305 rebuild the vortec 350 better value
Posted via Mobile Device |
Moderator
![]() Join Date: Oct 2008
Way better value in just using the 5.7 vortec. The 305 intake ports are shrouded by the block.
The intake manifold is Vortec specific so you won't use the earlier smallblock intake without drilling and tapping the heads. Google CS130 or AD244 alternator. That 98 could have either depending on whether the PO upgraded to an AD unit. Both are higher output than the 65Amp SI units in our trucks.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
