Gear question
I was wondering what a set of 4.10's would do to my truck. Right now its a 6.2/465/208 combo with 3.07 rears. Only reason i ask about 4.10 specifically is because they're free.
1984 blue and siver GMC K10 lwb - Grandad ordered it new with a 6.2 diesel and a 700r4. now it has a sm465 because teenagers are hard on wore out overdrives with 340,000 miles on them ![]() |
Re: Gear question
to be honest rpms will go way up and mpg will go way down, your truck will top out at about 55 it being a diesel with probably a 4000 rpm redline, but it will pull a ship down the road at 55, without a trailer. i wouldnt do it, now if it were a gas engine with tall tires i would but with your diesel and its low redline i wouldnt
Re: Gear question
Keep them tall one's. my 350 n 4.10's runnin 35's is at 2600 rpm at 55 n i think it's way too much.
Posted via Mobile Device |
Re: Gear question
That's what i thought. I have 33's but i think i just need a 5 speed and a little lower gear like 3.23 or so.
Re: Gear question
My blazer came factory with 3:73 gears and an overdrive. With 4:10s you will want an overdrive or a gearsplitter
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: Gear question
Could try n find some 3.42's... Probably closest and they come factory in some 3/4 ton's. but they're gettin rare... At least around here they are.
Re: Gear question
WIth the torque of a diesel, you really don't need that much gear reduction, and they want to rev lower, too.
T.Y.N Custom Works..... Because "Stock" Sucks! 1971 K 10 GMC Long Bed 1977 Formula T/A Frame off Resto-Mod ![]() 1995 FXDL Harley Low Rider 1985 C10 ShortWide 91 Burb front. |
Re: Gear question
my k30 with 6.2 465 with 4.10 does ok down the highway tires are 285 75 16. top speed at redline of stock 3600 is 91 mph. at 70. she gets high teens for milegle. my c20 with 3.42 and a 350 at 70 i get 22ish with a top speed around 120 at 5k rpm
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
Re: Gear question
you also have semi-tall tires on it, if i recall those tires are about 32 inches tall
Re: Gear question
ill take those 4.10's!!!!!!
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
![]() Join Date: Oct 2009
Re: Gear question
With 33" tall tires, there is nothing wrong with 4.10 gears if you have overdrive. Without overdrive, Id put in 3.73s. My old 75 GMC 3/4 ton had 33" tires and 4.10 rear, drove it daily for 2 years. I cruised it 70 mph on freeway vs. my 99 silverado with same size tires and 4.10 was purfect for the 5 years I drove it..it had overdrive.
Re: Gear question
I've got an 85 3/4 ton that has the factory 4.10 gears in it with a TH400. I'm looking at 3000 RPM at 65-70 and getting 10 MPG. I'm going to put in some 3.73's once I can afford to.
