Old 01-28-2013, 07:44 PM   #1
byates2
byates2's Avatar
Priming the Engine
I got my motor rebuilt about two months ago. The people who did it already primed it but ive had it sitting for about 2 months while i getting everything i need done.
I'm about ready to fire it up. Do i need to prime it again since its sat for 2 months
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 01-28-2013, 07:48 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Priming the Engine
It would not hurt and when you say "prime" I assume you are talking about priming the oil pump to get oil flowing to all the vitals before ignition, correct?
You can make your own oil primer from a used distributor or buy one ready to go.
TBONE1964 is offline   Reply With Quote
Old 01-28-2013, 07:52 PM   #3
byates2
byates2's Avatar
yea getting the oil distributed
Old 01-28-2013, 07:53 PM   #4
BigRed76
BigRed76's Avatar
You can also disconnect the power wire from the ignition coil and then crank the engine to build oil pressure. Though it won't be much pressure, it's enough that everything won't be dry on start-up.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-28-2013, 08:49 PM   #5
67gmcclassic
they make a tool for this. i dont think it is very expensive( maybe $20-30). you can also make one out of a screw driver and an electric drill. but if it were mine, i would prime it again. better safe than sorry.
67gmcclassic is offline   Reply With Quote
Old 01-28-2013, 09:22 PM   #6
FirstOwner69
FirstOwner69's Avatar
Autozone has the primer tool in the Loan-a-Tool program.
Here: http://www.autozone.com/autozone/acc...er=534529_0_0_
FirstOwner69 is offline   Reply With Quote
