01-28-2013, 09:23 PM | #1 |
LM7/4L60E complete pullout.
I came across a good deal on an LS1 so I am thinking about selling my LM7/4L60E swap before I stick it in the truck.
The motor is complete intake to pan with all accessories, the only thing it is missing is the throttle body(DBW). Has the OEM harness that's only been cut at the cab connector. Has 80k on it and is out of a side impact 03 Suburban. I have heard it run, it was quiet when pulled. Trans is a low mileage rebuild 2wd unit with LT1 converter - you'll need the GMPP crank spacer. It is a PWM unit so converter lock parameters can be tuned via HPT/EFILive. $1500 for motor/trans or $1300 for the motor, pretty firm on those #'s. I can drop this off at the local freight terminal, the motor is on a pallet and ready to go. SHipping usually runs $2-250, I will not do a shipped price, my zip is 50265. |
01-29-2013, 04:22 PM | #2 |
Re: LM7/4L60E complete pullout.
Bringing this back up.
I may be heading to St. Louis this weekend with an empty bed to pick up my LS1. I could drop it anywhere down in northern MO for dirt cheap if someone from there or KC wanted it. I could also throw this and the cherry picker in the bed and meet someone from KY/TN or KS with it. |
01-29-2013, 08:01 PM | #3 |
Wish i could swing it, bout a year to early.
Posted via Mobile Device |
01-29-2013, 09:14 PM | #4 |
I shot you a PM Daniel, all others responded to.
02-02-2013, 12:11 PM | #5 |
Motor sold, I have another one with 110k on it out of an 04 Silverado that ate a deer.
Complete top to bottom with accy's and harness/pcm. I would do $1100 for this one. On a pallet ready to go. |
