01-28-2013, 09:57 PM | #1 |
replacing leaf spring shackle bolts?
I am just installing some drop shackles and I had to cut two bolts off. Stock i am assuming, They appear to be 5 &1/2 inches long 1/2" ish, grade 8. However, the brand new grade 8s I can find locally are 5" (which is fine for length) 1/2" diameter grade 8s. The shaft of the new bolts seem to be smaller in diameter than the ones I cut out. So there is a fuzz of play?
What do I do?? |
01-28-2013, 10:13 PM | #2 |
Re: replacing leaf spring shackle bolts?
they're 9/16' bolts.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
01-28-2013, 10:57 PM | #3 |
Thanks!OK great, I guess the hardware store that I was at didn't carry the 9/16" bolts in grade 8. They do have to be grade 8 right??
I know this should be posted in the suspension forum, but the response in that specific forum doesn't yield as many informative responses. Thanks! |
01-28-2013, 11:21 PM | #4 | |
01-29-2013, 06:18 AM | #5 |
If your striking out at the local hardware store, try an industrial supply place (like Fastenal). IIRC, that's where I ended up when I did mine.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
02-01-2013, 08:48 AM | #6 |
Go to your local spring shop or trailer hitch shop and they will have the bolts. I replaced all my leaf spring bolts and got them from the same place that bent me my u-bolts.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
02-01-2013, 09:46 PM | #7 |
You can also mail order them from McMaster-Carr. I'm lucky enough to live close to one of their warehouses in Santa Fe Springs, CA, so i can order stuff over the phone and pick it up in about an hour.
