Rear axle U-bolts torque specs?
Does anyone know what the torque specs are for the rear axle u-bolts? This is for a truck with trailing arms and the two big u-bolts. I did a search but couldn't find anything...
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Rear axle U-bolts torque specs?
This was posted just awhile back.
I'll see if I can find the post. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
If this were a honda all bolts are tighten until it strips and back off a quarter turn.
I did some more searching and think I found the answer which is 145 ft/lbs. Sounds good to me!
my 63 work shop manual says 220-320. 125-165 for the pivots bolts with truck on the ground.
I don't think I can pull my bar that much.
Maybe I need a 4 foot bar. 320 divided by 4 = 80. I can do that.
Never Ending Projects
I actually bought a new torque wrench for doing these (and stuff on my big Dodge Ram truck). I did 220 ft. lbs. My new torque wrench goes to 250. It was hard to get it to click at 220. LOL
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
you have a range of 100. maybe it's given for new/used u bolt. the lower will be used and the higher will be for new, as it's lenghtening it when you torque it?
yep your body might slide on the floor under your arm power with this kind of torque on a short wrench!
Moderator
![]() ![]() Join Date: Aug 2011
Not sure if this will help on chassis torque specs:
http://www.chuckschevytruckpages.com...que_specs.html
Mine are at 140 ft-lbs and those rear wheels are still back there.
