Old 01-29-2013, 12:43 AM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Anyone know how to remove paint from VIN tag?
The PO painted over the door frame mounted VIN tag. I would like to try to remove the paint without destroying the tags. Does anyone have any ideas?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-29-2013, 12:46 AM   #2
Mister-B
Re: Anyone know how to remove paint from VIN tag?
I've had good luck with a product called Goof Off
Mister-B is offline   Reply With Quote
Old 01-29-2013, 01:00 AM   #3
FirstOwner69
FirstOwner69's Avatar
Those are polished stainless unlike some of the later models that had some paint on them. You could get away with using lacquer thinner or even stripper. Just go easy, don't use a lot and be sure you don't get any on your paint. Personally, I'd use a rag barely dampened with lacquer thinner and mask around the tags with some sort of tape that is unaffected by the thinner. You'd need to be very carefully with Goof Off also.
FirstOwner69 is offline   Reply With Quote
Old 01-29-2013, 01:14 AM   #4
geezer#99
geezer#99's Avatar
Try some steel wool.
Old 01-29-2013, 01:17 AM   #5
Beetle
Beetle's Avatar
I removed mine, put it in a butter bowl, poured some brake fluid in said butter bowl, took it out a few days later and it shined like a new penny. No joke!
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
Old 01-29-2013, 01:30 AM   #6
leddzepp
Moderator
leddzepp's Avatar
X 2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-29-2013, 01:34 AM   #7
Mister-B
That's cool, but then he'd have to fuss with rivets, which will probably never get back to looking like stock, no?
Old 01-29-2013, 03:01 AM   #8
FirstOwner69
As Mister-B said, don't remove them! If you do you'll have to start one of those dreaded threads about where to get rosette rivets and start a discussion about how illegal it is to remove the tags and for anyone to sell the rivets.
Also, as I mentioned above, the tags on your truck are highly polished. Even the finest steel wool will dull them, and you'd have to figure out how to polish them without removing them.
Old 01-29-2013, 05:38 AM   #9
stevencvn72
Kill Bill...et
stevencvn72's Avatar
8 posts and I just learned a crap ton of info about VIN tags. I love this forum!
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 01-29-2013, 09:07 AM   #10
Lattimer
Lattimer's Avatar
This is probably the best way.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-29-2013, 10:24 AM   #11
bruceman1968
bruceman1968's Avatar
Gentlemen, In this world there are a few things that you just don't do;
You don't tug on supermans cape,
You don't spit into the wind,
You don't pull the mask off the ol lone ranger,
And you don't drill the rivets on your VIN!!!
Try some thinner as suggested, But don't invalidate your truck over a little paint.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 01-29-2013, 10:35 AM   #12
Beetle
Beetle's Avatar
Yea you have to remove the original rivits but if he's not going for a nut bolt resto and trying to make a time capsule outta this truck the rivits on the vin tag should be the least of his worries. I mean who really sees the vin tag rivits anyways? That's why it didn't concern me to take the tag off, of course I am taking my entire cab down to bare metal and I took the tags off to get to the metal behind them. I just know brake fluid will remove the hide off an elephants butt so I used it to get the spray bomb primer off my tags. If the PO ain't concerned with where or how to get oe rivits I say go with this route. Especially if you don't want to mess up the paint on the trucks door jamb.
Jason
689 Short Step
68 Step
Old 01-29-2013, 11:11 AM   #13
derotoreut
derotoreut's Avatar
Agreed Jim, I don't plan on removing the tags. That's why I posted this question in the first place. If I was planning on removing them, getting the paint off would be easy. I want to keep them in place and work around it that way. I also don't want this post to turn into a discussion about the DO'S & DON'TS for VIN tags. Thanks for your input.
~ Dan
Old 01-29-2013, 11:11 AM   #14
tex_waco_usmc
Project Heaven in my 67!!!
In my case I had my cab completely rebuilt and the guy that did it removed them. When I went to re-register my truck from NC tags to TX tags they said I have to take it down to a DOT inspector... the first thing he did was look at the rivets on the VIN tag... Long story short, dont remove the rivets!!!!
tex_waco_usmc is offline   Reply With Quote
Old 01-29-2013, 11:16 AM   #15
derotoreut
derotoreut's Avatar
This is awesome, but it needs just a little revision to be more like the Jim Croce song:
You don't tug on Superman's cape,
And you don't mess around with VIN's!
I think I'm gonna keep that one.
~ Dan
Old 01-29-2013, 11:29 AM   #16
Beetle
Beetle's Avatar
I really do not understand how if you take the tags off your own truck to clean em up and rivit it back in place how its tampering with the vin. Maybe I'm being ignorant but if the vin tag is there, it matches the frame, matches the title how could any DOT man give you trouble over the wrong rivits??? Does he have a catalog of the allowed rivits??? I mean seriously you ain't messing with vins by taking a dern tag off a truck to clean it. Yes I can understand tag swapping between trucks is frowned upon but taking it off and putting it back should be completely legal. Sorry if I am hurting the purists out there by suggesting removing the original rivits...
Jason
689 Short Step
68 Step
Old 01-29-2013, 11:29 AM   #17
bruceman1968
Your right, that is the perfect last line. I can't beleive I missed that.
Striper or thinner, with the area around masked off, is how I'd do it.
You got a 3/4 ton cab & chassis there, what are your plans for it?
Old 01-29-2013, 11:49 AM   #18
derotoreut
derotoreut's Avatar
It was a cab & chassis. It's now a C20 with 383 stroker, Vintage Air, 8-lug front disc conversion, Ididit steering column, Lokar nostalgia floor shifter. Always finding something on it to work on... but that's the fun part of these trucks.
~ Dan
Old 01-29-2013, 11:57 AM   #19
too much stuff
Roadtrip!
too much stuff's Avatar
The thing is, YOU know it is still the correct tag, but the next guy may notice the wrong rivets and think the worst. (stolen cab or whatever) Once the original rivets are drilled and gone it is hard to prove anything. As far as legal, i think there is a fine line on what can/can't be done. Personally i would clean them in place.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-29-2013, 11:58 AM   #20
bruceman1968
Dan, 8-lug front disc conversion I love the fact that you kept it 8-lug. You got a really nice lookin truck! She's a beauty!
Old 01-29-2013, 01:27 PM   #21
FirstOwner69
Off topic, Dan, but seeing the H2s on there really makes me anxious to get mine back on the road! Looks great!
Jim
Old 01-29-2013, 02:54 PM   #22
JOJABOY
What size tire are you running on it?
JOJABOY is offline   Reply With Quote
Old 01-29-2013, 11:18 PM   #23
derotoreut
derotoreut's Avatar
285/70-17 on all 4-corners
~ Dan
Old 01-30-2013, 12:29 AM   #24
ls1nova71
ls1nova71's Avatar
Those VIN tags are originally polished stainless steel like others have pointed out, but that looks like a pretty decent paint job, aside from painting the tags, I guess. So My bet is once you get the paint off them, you're going to find that they were sanded when the door jambs were sanded, and may not be highly polished anymore.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-30-2013, 01:12 AM   #25
JOJABOY
I really like the look. What kind of front end lift did you do?
I know this is about VIN paint but I'm more interested in your truck suspension. LOL As for the VIN....
I would score around it with a sharp razor, mask of the paint with tape and carefully remove paint on plate with chemical stripper. Maybe use a q-tip with some aircraft stripper on it. Then once you most of the paint off the plate, mask of the protected area with new painters tape. Only this time add a few more layers of the painters tape to thicken it up. Then use a dremel with a buffing wheel and polish out the plate.
Now, back to the suspension and tires. LOL
