Old 01-29-2013, 11:56 AM   #1
northeimcustom
northeimcustom's Avatar
83 air over leaf shock placement?
so i am in the beginning stages of the AOL setup. where do i relocate the passanger side rear shock to? i would prefer a bolt on bracket of some sort.
thanks!
northeimcustom is offline   Reply With Quote
Old 01-29-2013, 10:41 PM   #2
northeimcustom
Re: 83 air over leaf shock placement?
Nothing?
Old 01-30-2013, 12:53 AM   #3
SCOTI
SCOTI's Avatar
The only way I've seen a Ride Tech style kit done was to flip the bracket on the rear end like the driver side & use a stud on the frame. The shock comes close but will clear the frame. This still requires cutting & re-welding the bracket to the housing.
When I did my 74, I made my own AOL system that didn't require relocating the shocks but I fabbed my own upper bag brackets & welded them to the c-notch/frame.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-30-2013, 02:19 AM   #4
Pro Performance
Pro Performance's Avatar
When I did my AOL, I had to relocate the lower shock mounts, since when the axle came up and hit the bed floor, the shock would hit the frame. The shocks don't go straight up and down, and are slightly angled. So, I left the drivers side angled to the rear, and re-drilled the frame on the passenger side in the same spot as the drivers. This allowed both shocks to go rearward. To eliminate the shock hitting the frame, I welded a shock mount onto the lower spring plate. It now barely clears the frame, but does work.
This kind of shows the lower mount.
Pro Performance is offline   Reply With Quote
Old 01-31-2013, 10:40 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
On my 77 I had Roger duplicate the rear mount on the opposite side. Unfortunately I don't have any clear pics to show what was done. He removed all the stock mounts and reused what he could to replicate the stock mounting point on the passenger side.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
