Old 01-29-2013, 01:24 PM   #1
87 3+3
Dually to SRW
I have an 87 crew cab dually that I want to make SRW.
It has a Dana 70 in the back, and I was wondering if I put a SRW fleet side bed on and changed the dually rims to normal rims, would the wheels line up with the bed flush like on a non dually truck?
Has anyone done this conversion and is this all i need to do to make the truck SRW instead of dually?
87 3+3 is offline   Reply With Quote
Old 01-29-2013, 01:36 PM   #2
meatwagon83
meatwagon83's Avatar
Re: Dually to SRW
you need a different rear, sell it and find a srw
meatwagon83 is offline   Reply With Quote
Old 01-29-2013, 06:13 PM   #3
87 3+3
Re: Dually to SRW
Is the dually Dana 70 too wide?
Old 01-29-2013, 07:52 PM   #4
82ccshorty
82ccshorty's Avatar
Re: Dually to SRW
It will be to wide. The wheels will stick way out. Like he said you'd be better off buying a single wheel. Have any pics of your dually?
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 01-29-2013, 08:28 PM   #5
87 3+3
Re: Dually to SRW
yes, but i cant figure out how to post them with the "URL" thing
Old 01-29-2013, 08:30 PM   #6
82ccshorty
82ccshorty's Avatar
Re: Dually to SRW
Are they on your computer or another website?
Old 01-29-2013, 08:30 PM   #7
jsavage977
jsavage977's Avatar
Re: Dually to SRW
I plan on doing the same thing to my truck. Its a crewcab longbed though i dont know if that matters. But I have heard that humvee h1 rims have enough negative offset that they will just bolt on to the drw hubs? Has anyone else hear this too? With the track width be the same as in the front as the rear? Sounds like a simple conversion to srw and get the sweet humvee beadlock rims too.. Anyone else know if this will work?
1988 GMC V3500 CCLB Cummins P7100 NV4500 NP205 D60 D70
jsavage977 is offline   Reply With Quote
Old 01-29-2013, 08:38 PM   #8
87 3+3
Re: Dually to SRW
on my computer
Old 01-29-2013, 08:42 PM   #9
82ccshorty
82ccshorty's Avatar
Re: Dually to SRW
When you hit post reply you click the paper clip choose photos hit upload and post the comment and there they are
Old 01-29-2013, 08:43 PM   #10
82ccshorty
82ccshorty's Avatar
Re: Dually to SRW
Old 01-29-2013, 08:46 PM   #11
82ccshorty
82ccshorty's Avatar
Re: Dually to SRW
Hit post reply click the paper clip choose you pics upload them and post comment
Old 01-29-2013, 08:47 PM   #12
jsavage977
jsavage977's Avatar
Re: Dually to SRW
its ok im a noob too ha ha
Old 01-29-2013, 09:06 PM   #13
87 3+3
Re: Dually to SRW
Old 01-29-2013, 09:09 PM   #14
82ccshorty
82ccshorty's Avatar
Re: Dually to SRW
Looks good Don't change it. It would be cheaper to buy a srw then to change it
Old 01-29-2013, 09:13 PM   #15
87 3+3
Re: Dually to SRW
Alright, awesome!
Thanks,
There it is above. It is a 1987 4X4 with a 454tbi and standard sm465 4 speed transmission. I just bought it not too long ago. I am a junior at high school and its in my auto shop class and i am working on it in there.
Old 01-29-2013, 09:17 PM   #16
87 3+3
Re: Dually to SRW
Yeah i think i will just leave it dually if it is going to be that much work. I don't have that much of a problem with it and i will be hauling a camper and towing trailers. I was just thinking it could be more of a daily driver if it was SRW.
Old 01-29-2013, 09:22 PM   #17
bohmankid
bohmankid's Avatar
Re: Dually to SRW
I have been thinking about buying a dually and changing it to single rear wheel as well because the crew cabs are hard to come by where I am and the dually's are selling for amazingly cheap. If I can't find a cheap single rear wheel I will probably be buying a dually and doing this swap. Can't be any harder than swapping a bed and axle, right? front axle swap as well?
bohmankid is offline   Reply With Quote
Old 01-29-2013, 09:25 PM   #18
87 3+3
Re: Dually to SRW
I just looked at your truck on your page and that is a good looking crew cab. I want to get mine at that ride height. What size tires are those, because they go perfect with that 4in lift?
Old 01-30-2013, 11:55 AM   #19
Desert1957
Desert1957's Avatar
Re: Dually to SRW
Nice looking truck, Must really want a single wheel to change your look.
Desert
Desert1957 is offline   Reply With Quote
Old 01-30-2013, 12:18 PM   #20
mopar346
Re: Dually to SRW
Truck looks awesome, let it be. The gas it would eat as a daily driver would pay for a shorty with a SB in little time.
mopar346 is offline   Reply With Quote
Old 01-31-2013, 11:35 AM   #21
87 3+3
Re: Dually to SRW
Thanks for all of the help guys!
I have decided i will keep it dually, especially since me and my brother are going to buy a camper for it pretty soon. Then i will save my money for Alcoa wheels, a lift and tires. And after looking at duallys on this forum, i am starting to really like the fenders on the bed.
Old 02-01-2013, 04:36 PM   #22
jsavage977
jsavage977's Avatar
Re: Dually to SRW
Yup 4" lift springs in the front and 3.5" blocks in the rear. I cant remember the tire size off hand but I think they are 265 75 r16
Old 02-01-2013, 08:09 PM   #23
chevy1ton
chevy1ton's Avatar
Re: Dually to SRW
You can use the hummer wheels with the DRW fr hubs, this is commomly done. The hummer wheels are affordable and available and SRW fr hubs are hard to find and expensive to buy.
You would have to get a SRW 14blt ff rear (check gear ratio) to replace the D70 which shouldn't be too hard to find (I have 3 out back). You should be able to use the same bed if you remove the fenders.
87 3+3 I think your truck looks good the way it is.
chevy1ton is offline   Reply With Quote
Old 02-01-2013, 08:19 PM   #24
mopar346
Re: Dually to SRW
I believe the bed wheel wells are opened up on a dually bed so removing the fenders will leave an unsightly opening. Look inside the rear fender and you will see if I am right.
I have heard that the housing are the same, it is the hubs, backing plates, and axles are different. Not sure if that is true or if it applies to the 70. Hopefully someone more knowledgeable will clarify if it is an option. IF you are still giving it any thought, I personally would let it be, its what most of us are would love to have.
Old 02-01-2013, 08:24 PM   #25
meatwagon83
Re: Dually to SRW
i think its awesome the way it is, how is making it a single going to make it a better daily?
