Old 01-29-2013, 07:14 PM   #1
dhughins
dhughins's Avatar
Smile i saw the post about headers and i'm sick of mine
What exhaust manifold would I get I have a 69 with a 1976 305 in it. I just swapped in new header gaskets and it was a pain. I noticed that my sparkplug on drivers side is against them. If I wanna change plugs gonna have to pull header. How stupid. It also depends on cost. Might have to keep what I have for awhile? Just thinking.
dhughins is offline   Reply With Quote
Old 01-29-2013, 07:54 PM   #2
jjhare
jjhare's Avatar
Re: i saw the post about headers and i'm sick of mine
My 72 has a 305 from an '86 and it has the ram horn manifolds. Probably find a used set pretty cheap at a junkyard.
1972 C10 CST LWB
jjhare is offline   Reply With Quote
Old 01-29-2013, 08:28 PM   #3
dhughins
dhughins's Avatar
Is there any difference in a 72 or 86 exhuast manifolds? Are they cubic inch specific or will ones off a 350 or any small block Chevy work?
Old 01-29-2013, 08:59 PM   #4
jjhare
jjhare's Avatar
These were the 72 manifolds off a 350 and they bolt up just fine.
1972 C10 CST LWB
Old 01-29-2013, 10:05 PM   #5
truckster
truckster's Avatar
One of the many reason's I'm getting rid of my headers is that I have to crawl underneath and use an open-end wrench to change my number 2 plug.
truckster is offline   Reply With Quote
Old 01-30-2013, 08:26 AM   #6
b.eddy's72
b.eddy's72's Avatar
Any from a SB should work fine. There are MANY MANY different ones out there. Used are a dime a dozen but new ones arent to bad. The Ramhorns are cool that jjhare spoke about. I wish you were closer because I have probaly 20 different pairs of stock manifolds. Yeah Im kinda a horder If you buy used look them over well and make sure they are not craked. The truck style with the spreader bars are a good way to go also. Just my opinion
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 01-30-2013, 09:40 AM   #7
steelhorse
steelhorse's Avatar
They make spark plugs that are shorter than normal for this exact reason. Not sure what brand the are but they showed them on horsepower tv last week.
steelhorse is offline   Reply With Quote
Old 01-30-2013, 10:53 AM   #8
69GWC
I have a set of headmens on my truck and then I stuck in a set of short plugs (Accels) so I have more clearance on the plug wires. But even before that the plugs were not to hard to change out.
Now my Nova is right tight thats for sure.
69GWC is offline   Reply With Quote
Old 01-30-2013, 12:48 PM   #9
truckster
truckster's Avatar
I've used the shorty plugs from Accel, but the header tube is still in front of it; I can't get a socket on it.
Old 01-30-2013, 10:19 PM   #10
Boog
laying low
Boog's Avatar
Not all manifolds from small blocks will fit a 67-72 truck. The ones that run below the spark plugs tend to interfere with the frame and engine mount stands. The ram horn manifolds run up over the plugs and have a center dump to clear the stands and crossmember and frame. You need the angled exit ram horns on a 2 wd and a straight down exit can be used on a 4 wd application.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-30-2013, 11:40 PM   #11
airdale94
airdale94's Avatar
As Boog said the center dump (strait down) are for the 4X4's, and the angled back are for the 2wd's. The later style are a "log" type. I diddn't know they would interfere with the frame. You wouldn't want those over the ram horns anyway. The ram horns will bolt up to at least all 86 and prior SBC heads.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 01-30-2013, 11:55 PM   #12
Ziegelsteinfaust
Sanderson has cast headers that offer the best of both worlds. Plus you can often find them cheap used.
Ziegelsteinfaust is offline   Reply With Quote
