![]() Join Date: Nov 2011
Uneven body lines
Has anyone had a problem with the body lines bed to cab not lining up. Im doing a frame off and im running into this problem pass side is perfect while the drivers is a half inch off
Posted via Mobile Device |
Re: Uneven body lines
What is off, cab to high, bed to high?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Bed seems to high on one side doesnt makeany sence
Is that with everything properly torqued down, can and bed?
Cluster King
![]() Join Date: Nov 2012
You might have to shim the drivers side of the cab a little. 1/2 inch is pretty big difference. It maybe that your frame is tweaked a little, not sure about that but it is possible. Do you have new cab mounts?
Ya i have new cab mounts i guess ill have to make something work thanks for all the help fellow c10ers
put a 4 foot level in the rear window [if not installed] and see how bad that looks then put the level on the tailgate this might help you decide what is off. I had to do this to find out my frame was tweaked and had to shim the box on driver side 3/8 inch to 0 at the back corner
Fuzzy |
ill try that thank you
