01-30-2013, 02:27 AM | #1 |
6.2 hard start
ok i am really starting to to hate my truck. finely got it running good looking good and no elec problems. now the dam thing will not start in the morning at all. she starts good in the cold with just the plugs. here is what it takes to get her going after sitting all night. crank it alll dam day till that batts are dead or give it a shot of ether witch i dont like. and now it is getting worse buy the minute. it was fine after it was going for the day now after 2 hours of sitting she will start but takes a good 15 sec of cranking. plugs are working fine i tryed changing the filter and that didnt help at all. when it wont start i am geting fuel at the injectors not alot but dont know what should be there. one thing i am thinking is the mechanical fuel pump is bad so its not holding the prime?. this motor has always started fine even down in the single digets. once she is going seems to run fine. is ther any thing i should check? this is the thierd time this truck has f**ked up before a trip and this trip that i am going on nect wensday is 600 miles to get a nother truck for parts. HELP lol thanks, mike
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
01-30-2013, 02:36 AM | #2 |
Re: 6.2 hard start
Are you using #1 or #2 diesel fuel? How cold is it getting? Maybe you have a leak somewhere that is letting air into the system and you're having to bleed it out each time you try and start it. It sounds like your glow plugs aren't working or maybe that the engine doesn't have the compression it needs to heat the cylinders up and ignite fuel.
01-30-2013, 03:23 AM | #3 |
Re: 6.2 hard start
i think it is winter blend fuel. it has been alot colder and started fine. plugs are working 12v at then and no open elemnts in them.
01-30-2013, 03:37 AM | #4 |
Re: 6.2 hard start
Not to take away from this forum in ANY way, but I know there is a TON of knowledge and experience in regards to the 6.2L/6.5L engines at www.thetruckstop.us I know for a fact that the occasional diesel-site drama that has plagued the larger sites does not exist over there, that is one of the reasons that site was founded... (I've been there since the get-go.)
EDIT: First thoughts: fuel tank sock, fuel pump (like you suspicion), plugged fuel tank cap (not venting). Also, not sure which one you're running now, but consider the gear-reduction starter and do NOT forget to put the brace on the front of it. I know it's a PITA, but it is worth it for starter longevity.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 Last edited by 83GMCK2500; 01-30-2013 at 03:44 AM. |
01-30-2013, 03:38 AM | #5 |
Junior Member
Re: 6.2 hard start
Does the truck turn over fast enough? Dirty battery cable connections or a weak battery could cause slow cranking speed and lead to lower ignition temperatures. Just that quick shot of ether might be giving it enough additional cranking speed to sustain combustion.
Otherwise I agree that it sounds like you are losing prime on the fuel system. The most common leakage point for a 6.2L of our vintage has to be the Stanadyne Model 80 Fuel Filter Housing. The air leaks in either through the filter restriction indicator, the heater element or the vent/drain plugs. I rebuilt my Model 80 with all new Viton O-Rings and it reduced my cranking times from 20 seconds to only a few revolutions before ignition. It could also be the mechanical fuel pump, but if there is no entry point for air the system should quickly re-pressurize once the pump begins to pump. Adding a fuel pressure gauge after the Filter might be a good troubleshooting tool.
If it wasn't for the last minute, nothing would ever get done. 1953 3800 - SRW C&C Dump - 216/SM420 1985 K30 Scottsdale - SRW - 6.2/SM465/NP205 (Sold) |
01-30-2013, 07:31 AM | #6 |
Re: 6.2 hard start
NEVER ether a 6.2 with working glows! The resulting bang bends rods and breaks cranks.
WD-40 is better suited as a light oil that works well, hit the glows, then start cranking and give it a light mist of WD40 (without the air cleaner, and while cranking!). FYI, once you have to start using ether, these become 'ether sluts', and then refuse to start without it. dieselplace has a good 6.2 section also. I found on mine, in order: 1) Replaced glows with self limiting 60G's and a manual switch, and give it another 10-15 seconds after the factory timer quits, really helped (wired in parallel so that the after glow works too). 2) New big batteries, cleaned high quality connections (particularly the double on the RH battery, if it gets dirty the connection will get hot and melt the batttery post. BTDT). 3) make sure the starter spins the motor fast enough, clean connections (very common problem) and replace starter if needed. 4) put a clear hose on the return at the front of the IP, if you get bubbles when it starts you have an air leak problem (which led to new hoses and lines for me, and soon to replace the Model 80 with a spin on setup). 5) below 20 degrees plug it in for an hour. 6) injectors and pump I spent about $600 and 2 weekdends to get mine set up. I walked out a couple weeks ago, truck has been sitting since Novemeber (tore the rear end up), fired on the 2nd revolution.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
01-30-2013, 11:33 AM | #7 |
Re: 6.2 hard start
ok guys this is what we go so far.
1. new batts 2. new starter 3. she deff cranks fast eniugh. 4. i will try the clear line on the return today. 5 idk but i really dont want to drop 600 bucks on it right now lol
01-30-2013, 01:47 PM | #8 |
Moderator
Re: 6.2 hard start
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
01-30-2013, 02:30 PM | #9 |
Re: 6.2 hard start
X2 on fuel filter housing. Have a Deere skid loader with same filter and housing and similar symptoms. Had to prime to start in mornings. Replaced housing and problem disappeared. I fortunately never had that problem with my 6.5, but PMD issues trumped other problems.
Posted via Mobile Device |
01-30-2013, 07:20 PM | #10 |
Re: 6.2 hard start
is there a fuel shut off relay or cut off switch on top of motor
01-30-2013, 07:50 PM | #11 |
Re: 6.2 hard start
I just had the same runaround with a 88V30/6.2. My problem ended up being the fuel filter assembly on the firewall. There is a pressure sensor in the back of the fuel filter unit. The O ring that keeps it from leaking goes bad. Irt will run good all day. If it is shut down over a couple of hours it is hard to start. If you diconnnect the "pink" wire on rhe injector pump and go through bleading procedures it will start, no problem. Eventually I has to remove the sensor from the filter unit and tap the hole for a screw. The filter assembly is not avalable new any more and junk yard units have the same problem. You can also replace the fuel filter assemply with an after market unit such as the type used on tractors. Some oil furnice filter units will work too.
1988 V30/6.2/Sm465/NP205/5x6 4.56 axle/12,000 lb.GVW/Ramsey L600 front winch,Chelsea 321PTO on trans/ Ramsey L800 rear winch,Chelsea 352PTO on transfer/ custom steel flat bed with rear rollers. |
01-30-2013, 08:01 PM | #12 |
Moderator
Re: 6.2 hard start
She starts so the fuel cutoff solenoid works. The fuel pump is mechanical so it only runs when the motor turns.
01-30-2013, 08:48 PM | #13 |
Re: 6.2 hard start
ok so we got an update. i put in some clear line to see what is going on. out of the ip i have some are vary small bubbles. on shut down get alot of air in the same line but coming form the return side. i did change out the feed line to the ip. that sucked lol. when i had the clear line in after the filter i had not air there witch is way i changed the line thinking the other end maybe bad. how do i test the ip pump and the mechanical pump? thinking the presseurs on cranking are not high enough and there sucking air??? also could it be a bad return line on the injectors??? thanks, mike
01-30-2013, 09:17 PM | #14 | |
Moderator
Re: 6.2 hard start
"An intermittent no-start condition on some diesel engines could be due to an inoperative check valve in the engine fuel delivery (lift) pump. This condition could occur after the engine has been running, then stopped for a short time. Fuel could drain past the inoperative check valve back into the fuel tank. To correct this condition, replace the fuel delivery (lift) pump." --Page 366 GM_STG_16015_05_1C_1987_The_6_2_Liter_Diesel_Engine.pdf
01-30-2013, 09:21 PM | #15 | |
Re: 6.2 hard start
When was the last time you replaced your LIFT PUMP? Its on the passenger front side of the engine block, looks like any old Small Block manual pump The DB2 Injector pump has enough power to effectively act as a fuel pump. HOWEVER, you still need to get fuel to the IP to get it going, then it can take it from there I found out my 6.2 was running with a blown fuel pump for a while, took a lot of cranking to start. $20 dropped at NAPA later, and I was golden Another issue with the fuel pump: There was actually a GM Recall/Service Bulletin on our 6.2's original lift pump. They have a sort of "anti drain back valve" in them, to keep the diesel lines going to IP "primed" when sitting. They updated the lift pump with a new design, eliminating the fuel draining back issue (thats maybe why it takes so long to crank over and start, fuels already back at tank) Quick way to check your lift pump Unscrew the pressure output fitting going from pump, you can do this from under the truck. Put bucket underneath. Pull pink wire off of top of IP (kills the ignition, keeps her from starting and sucking air) Turn over the truck for 5 seconds. Go back to bucket. See if fuel was being pumped, or if it was just trickling out or nothing comes out No fuel = No bueno. Go drop $20 on a cheap pump at napa, and your truck will start at the FLICK of the key after 10 seconds of glow plugs. -Sterling |
02-02-2013, 12:17 AM | #16 |
Re: 6.2 hard start
ok so i went back to the drawing bord and started all over. rechecked for air no air ok good then moved on. rechecked the plugs after pulling them and what do i find?? 6 of them are open circs and the 2 that did have cont where 180k ohms and 3600 ohms. yea f!!ked so got 8 new plugs form autozone for 10 bucks each. got the acdelco 60g. put those in today and seems to work will no better in the mornin after she is good and cold
02-02-2013, 10:40 AM | #17 |
Re: 6.2 hard start
Reading through this I wasn't convinced you had glow plugs. If problem persists,it could be the controller. My '85 needs one right now. Last winter it would crank a while,fire,but not stay running. bout as many times as not,it would barely start the second try. The rest of the time,that was it,the batteries couldn't cut it. Batteries are not the issue,glow plugs all new and functioning. Spring till winter everything fine. Now,same thing this winter. All summer long I knew I needed a controller and never bothered. It's just not giving enough glow time for once it's down to so cold. The batteries just can't take turning a cold high compression motor.
02-02-2013, 12:58 PM | #18 |
Moderator
Re: 6.2 hard start
Glow plugs or air in the fuel.
When you said the plugs worked I assumed you already tested the glow plugs. Glad you found it.
02-04-2013, 10:27 PM | #19 |
Re: 6.2 hard start
Unfortunately, the AC 60G glowplugs are slower to heat up than your previous glow plugs. As a result, your controller probably won't give it sufficient time to ensure easy starts. I ended up using a push button to activate the glow plugs. I've ran the glow plugs for up to 45 seconds without any issues.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
02-04-2013, 11:14 PM | #20 |
Re: 6.2 hard start
yea i thought that i did check them the right way but a few to many drinks will make you look like an ass, lol my plugs are on a toggle switch so i can time they as needed
