Old 01-30-2013, 12:53 PM   #1
chika989
1987 Chevy 350 Loss of Power On Acceleration
My 1987 Chevy 3/4 ton pickup has a lack of power on acceleration and both exhaust manifolds turn cherry red. Exhaust manifolds will also turn red (although not as hot) if truck is just sitting running in the yard. This truck currently has no catalytic converter. Any suggestions? Thanks so much!
chika989 is offline   Reply With Quote
Old 01-30-2013, 01:01 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 1987 Chevy 350 Loss of Power On Acceleration
Sounds very lean. Anything done to the engine performance wise? What's the setup?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-30-2013, 01:09 PM   #3
chika989
I was getting a code 42 on this truck so replaced the white EST wire going to ignition module. This is a stock 350 throttle body. Thanks for replying.
Old 01-30-2013, 03:25 PM   #4
rfmaster
rfmaster's Avatar
Code 42 also could mean that you have set EST connector open. If this is the case timing is not control by ECM and is fixed at what ever base timing was set - usually 0 deg. This would explain poor running engine. Set EST plug is a single wire plug usually found next to brake booster and has beige-white stripe wire. Make sure that at idle your timing is around 18 deg +/-3 deg bouncing as this would indicate that ECM is adjusting timing.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 01-30-2013, 04:33 PM   #5
Damon23
Damon23's Avatar
Do you have catalytic converters? They could be getting plugged.
Damon23 is offline   Reply With Quote
