Old 01-30-2013, 03:59 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
Painless wirring problems.
I just finished wirring in the headlight brake lights and turn signals and none will work. I checked and none have power when I turn the lights on but the dash lights up. What did I forget? Or what could be wrong I'm stumped right now. Fuses are all good too. Any suggestions?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 01-30-2013, 04:05 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Painless wirring problems.
Grounds? Half of the under hood connector that goes to the fusebox?
Sorry for the obvious silly stuff but it may be somehting silly.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-30-2013, 04:16 PM   #3
Wildstreak
Wildstreak's Avatar
No it could be something silly that I've forgotten. Maybe I should make sure the "grounds" are actually grounding.
57 chevy 4x4
68 burb 2wd:
Old 01-30-2013, 04:19 PM   #4
Wildstreak
Wildstreak's Avatar
Am I suppose to ground the tail lights too. I didn't see that in the instructions.
57 chevy 4x4
68 burb 2wd:
Old 01-30-2013, 04:58 PM   #5
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Make sure circuit breaker for head lights is installed in fuse block.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 01-30-2013, 05:29 PM   #6
Wildstreak
Wildstreak's Avatar
Is that the one beside the turn signal? I checked for power at the switch and it has power.
57 chevy 4x4
68 burb 2wd:
Old 01-30-2013, 06:17 PM   #7
Wildstreak
Wildstreak's Avatar
Ok just checked some more stuff and the high beams have power but no low beams and no power to the turn signals or park lights or the rear. I've put one of these in my Cheyenne and I'm using it as a reference but everything looks the same.
57 chevy 4x4
68 burb 2wd:
Old 01-30-2013, 10:27 PM   #8
Wildstreak
Wildstreak's Avatar
Also when I press the brakes the dash lights come on. Something's gotta be causing this.
57 chevy 4x4
68 burb 2wd:
Old 01-30-2013, 10:36 PM   #9
Wildstreak
Wildstreak's Avatar
Ok I fixed the head lights and tail lights the plug hadn't seated firmly enough. But my brake lights won't work and the dash lights up when I press the brake pedal.
57 chevy 4x4
68 burb 2wd:
Old 01-30-2013, 11:58 PM   #10
junior43
junior43's Avatar
Sounds like it is backfeeding from lack of good ground.
junior43 is offline   Reply With Quote
Old 01-31-2013, 12:01 AM   #11
Scott>72-GMC
Scott>72-GMC's Avatar
Im betting ground
Scott>72-GMC is offline   Reply With Quote
Old 01-31-2013, 12:26 AM   #12
Wildstreak
Wildstreak's Avatar
Turns out that brake clip by the pedal was on wrong flipped it and brake lights work now. And the box wasn't grounded enough so it gave a week light. I ran a ground wire from a good source and everything works brighter. Funny how something like that flipped wire can make the dash light come on instead of the brakes
57 chevy 4x4
68 burb 2wd:
Old 01-31-2013, 12:29 AM   #13
Scott>72-GMC
Wiring is always fun glad u got it all sorted out
