Old 01-30-2013, 04:50 PM   #1
AirSpeed
AirSpeed's Avatar
Smaller HEI cap?
I put an HEI dist on my 72 GMC 4X4 a while back and the cap almost touches the firewall. The distributed came off an 80s Chevy truck. Does anyone make a smaller cap that will fit?
AirSpeed is offline   Reply With Quote
Old 01-30-2013, 04:53 PM   #2
kwmech
Re: Smaller HEI cap?
Not with the internal coil
Old 01-30-2013, 04:55 PM   #3
69GWC
Mine is the same way, you will have to get a different dizzy if you want more room.
69GWC is offline   Reply With Quote
Old 01-30-2013, 04:56 PM   #4
AirSpeed
AirSpeed's Avatar
Has yours ever hit the firewall?
Old 01-30-2013, 04:58 PM   #5
kwmech
It's pretty common for them to rub slightly on a 4x. If it is rubbing pretty hard you may want to check out the cab mounting and the engine mounts also
Old 01-30-2013, 05:01 PM   #6
69GWC
Not that I know of, also my valve cover is real close as well but they are taller then stock. It does make it alittle harder to install the plug wires on the back side.
Old 01-30-2013, 05:06 PM   #7
AirSpeed
AirSpeed's Avatar
Thanks all. Any recommendations for a cap and external coil? What do I look for? Or would it be better just to buy a new distributor?
Old 01-30-2013, 05:16 PM   #8
69GWC
I cant really help with that, I would like to hear as well what every recommends for a smaller distributor that is as easy to install as a HEI and what coil to o with it.
