01-30-2013, 08:46 PM | #1 |
Old member
Helper air bags
Ok I want some input from all you bagged guy's. I installed the helper bags a few years ago and they work great.
I have to put air to them through the schrader valves in the back bumper. I bought a Buick Park Ave Ultra air compressor for the suspension and mounted it. I have the Delco pleasure-lift gauge and air valve to release the air and I mounted a momentary switch to turn the compressor on/off. I didn't want a regular on/Off switch because I was affraid I would forget the switch and blow the bags up. My question is should I have anything else in the system to make it ride better for the system I have installed. Opinions suggestion's...
02-02-2013, 02:14 AM | #2 |
67-72 parts collector,…
Re: Helper air bags
I would remove the spring and install just a standard 2600 bag,... for a better ride.
Some rear shock relocators and an adjustable track bar also.
02-03-2013, 08:34 PM | #3 |
Old member
Re: Helper air bags
I have all of that already installed except for the bags and I'm not ready for all of that yet.
02-03-2013, 08:46 PM | #4 |
Re: Helper air bags
Those must be old pics.
There is no shock relocator in those pics.
02-03-2013, 09:56 PM | #5 |
Old member
Re: Helper air bags
Yes they are. Sorry about that. Here is some of the new "No limit kit"locator's.
02-03-2013, 10:08 PM | #6 |
Re: Helper air bags
I was looking at this one,...
02-03-2013, 10:15 PM | #7 |
Old member
Re: Helper air bags
Yea those are several years old pictures before I had the relocator's on it.
It rides much better now.
