Old 01-30-2013, 09:52 PM   #1
hyatt
48-55 suburban gas tank
who makes fuel tanks with pump in tank for subs
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 01-30-2013, 10:00 PM   #2
arturo7
arturo7's Avatar
Re: 48-55 suburban gas tank
If ya find one lemmee know...
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 01-30-2013, 10:45 PM   #3
youngrodder
youngrodder's Avatar
You could always buy a new tank and have a pump retro fitted into the tank. That is what I did (only for my truck). I used a company called Rock valley auto antique parts. They also make custom SS tanks. I wanted to keep my costs lower so I just sent them a new tank which they retro fitted a pump inside and shipped it back to me.
Here is their website http://www.rockvalleyantiqueautoparts.com/ndex.htm
Good luck
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-31-2013, 03:11 PM   #4
_Ogre
_Ogre's Avatar
rare as hens teeth. no one remans them, to bad too, it makes the ideal way to get the tank out of the cab.
on the 55-59 trucks the tank hangs inside the frame
shop air compressor timer
Old 01-31-2013, 03:42 PM   #5
NEWFISHER
NEWFISHER's Avatar
Heres the Repro Suburban/panel/under body Truck tank I used from Jim Carter.
http://www.oldchevytrucks.com/cart/p...9&i=10524|||||
You could use a universal sending unit and modify it to accept an in tank style drop in pump or used the lower left corner bung provided on the tank to plumb an external frame mounted pump ( which I would do ).
http://www.brotherstrucks.com/prodin...number=GTS66PN
with a airtex pump
http://www.summitracing.com/search/p...ank-fuel-pumps
or frame mount as descibed comming out of the lower left corner bung on the tank.
http://www.summitracing.com/search/d...ctric-external
These guys will make a modified sender/pump for you
http://tristarrradiator.com/Custom%2...ed%20Page.html
NEWFISHER is offline   Reply With Quote
Old 01-31-2013, 03:52 PM   #6
mr48chev
mr48chev's Avatar
I didn't even know anyone made that tank as a reproduction. I've still got the stock one out of my truck but it's in pretty rough shape.
My ongoing truck projects:
Old 01-31-2013, 04:24 PM   #7
hyatt
thanks for info
1946 car hauler
1948 surburban
1937 chevy sedan
1967 ss396 chevelle
Old 02-01-2013, 01:28 PM   #8
_Ogre
_Ogre's Avatar
cool reman info.
so 47 48 trucks had the tank under the bed and gm improved on that by putting the gas tank in the cab???
wtf?
anyone running a 47-55 truck should look at this
Old 02-01-2013, 09:02 PM   #9
crossfire84
crossfire84's Avatar
try this www.tanksinc.com
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 02-02-2013, 12:18 PM   #10
sweet70beast
sweet70beast's Avatar
wtf?
Makes a lot of sense huh?
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
