Old 01-30-2013, 10:22 PM   #1
mrsmothers
I know I know but I need help
So I have a really common question I know its in the faq section but I Its still not clicking. So..... I cut my bed down and now need to cut the frame. well in the faq section its a bare frame. I dont want to pull the cab and I would love to leave the bed on may not happen but it would be nice. I need pictures and mesurements on how to do so. The rear is cut now I need to know where to cut the center. Its a coil spring truck dont want to move center cross member if possible.
mrsmothers is offline   Reply With Quote
Old 01-30-2013, 10:48 PM   #2
Scott>72-GMC
Scott>72-GMC's Avatar
Re: I know I know but I need help
Be alot easier tore down. Someone might chime in
Scott>72-GMC is offline   Reply With Quote
Old 01-30-2013, 11:04 PM   #3
mrsmothers
I know but I am haveing to do the work in the shop at work and I only have access for a day or so. Sadley this is the only truck I have so I cant tear it down and tow it up there.
Old 01-30-2013, 11:05 PM   #4
Scott>72-GMC
Hmm I can see ur point.
Old 01-30-2013, 11:08 PM   #5
mrsmothers
early classic did it but they cut behind the cab and the faq section cuts under the cab.
Old 01-30-2013, 11:34 PM   #6
SS Tim
SS Tim's Avatar
If you cut it behind the cab then you have to move the crossmember. Being as it is a suspension crossmember I would much rather have it factory riveted than moved and bolted.
This is not the sort of project to blow through and cut corners. Maybe a cheap car for interim transpo is your best bet.
SS Tim is offline   Reply With Quote
Old 01-30-2013, 11:12 PM   #7
scrapmetalart
Junior Member
shorten it in the straight section in front of the trailing arm crossmember. you them have to move the rear cab mounts back as they will move forward the same amount as you remove from the frame
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 01-30-2013, 11:21 PM   #8
SS Tim
SS Tim's Avatar
Best section to cut the frame is under the cab forward of the rear cab mounts which get moved.
There are LOTS of threads on this. But this one is very clear on the frame work.
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
Old 01-30-2013, 11:42 PM   #9
Scott>72-GMC
Hate to be going down the road then all of a sudden dragging frame.
