Old 01-31-2013, 10:26 AM   #1
Koffer
Red face Block drain ?
Hello all
I did search but came up with just stuff for the V8s
Stupid ? of the day
Does a 292 have a block drain ? I need to replace the waterpump gasket (again) and would like to drain the block to make alot less mess and use the antifreeze since its under a month old.
Pulling the lower hose really didnt help with the mess as the hose fitting in the waterpump is still way higher then bottom of the pump housing.
Thanks all
Todd
Koffer is offline   Reply With Quote
Old 01-31-2013, 10:30 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Block drain ?
Do you not have a petcock at the bottom of the radiator?
Old 01-31-2013, 10:35 AM   #3
Koffer
Re: Block drain ?
Yeah , even draining the rad and pulling the lower hose off the waterpump the block still pretty much full
Old 01-31-2013, 10:47 AM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Block drain ?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 01-31-2013, 10:48 AM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Block drain ?
It should have a drain plug but keep in mind it's been on for years and very hot so may not come loose
1991 GMC Jimmy 4x4
Old 02-10-2013, 11:56 AM   #6
Koffer
Re: Block drain ?
Thanks , found it under all the crud covering the motor , little harder to find in the P10 , nothing like the pickups where you can climb in and close the hood
Had to drain it again as the heater core (at least I had bought it and sitting on the shelf knowing it would happen sooner) took a dump , well that finished off the cooling system I replaced everything. Radiator,waterpump, upper/lower hoses heater core and lines.
Now on to the next item on the list .
