Old 01-31-2013, 11:03 AM   #1
lil_sahara450r
Power steering hoses
Hello again guys!
First off I'll tell y'all what I already have and know, and then I'll ask my question so there is no confusion. This is for a 1966 SWB with a 70's 350.
What I already have:
Captainfabs bracket and coupler (AWESOME quality!)
Power steering gear box from a 1975 C10
Power steering pump from 1975 C10
Brackets to install pump on block from POL
What I need to know is what hoses to buy (pressure and return hoses). I have read that some hoses don't fit well and the inner fender needs to be cut, I am tryng to avoid this issue. So to you guys that have already done this, what did you get?
Thanks in advance!
lil_sahara450r is offline   Reply With Quote
Old 01-31-2013, 11:32 AM   #2
tincan1966
tincan1966's Avatar
Re: Power steering hoses
I would use hoses for a 1975 C10. They should lay flat on top of framerail, just like on the '75. If anything, very minor(maybe a 1/4") will need to be trimmed off the lip of fenderwell directly above hoses.
tincan1966 is offline   Reply With Quote
Old 01-31-2013, 04:28 PM   #3
slepysal
slepysal's Avatar
On my 1960 I went with one off of a 72 a/c delco # 36-355240 for the pressure hose and a # 36-350020 return line .
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-31-2013, 11:39 PM   #4
lil_sahara450r
thanks for the replies guys. slepysal, would you happen to have a pic or two?
