Old 06-12-2003, 11:59 AM   #1
BigRed
Return Spring/Kickdown Cable Setup
Anybody have a picture of how their return spring is setup on either a Edelbrock or Carter carb? I just changed out my Holley for a Carter and can't seem to get the return spring to work right when my kickdown cable is hooked up. I took the kickdown cable off because I need a new one so now I have the return spring sitting on that linkage on the carb.
Thanks!
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 06-13-2003, 09:14 AM   #2
BigRed
Ok, I don't necessarily need pics, but how about a description.
Scott Shelbourne
Old 07-04-2003, 05:54 PM   #3
82 'ject
Alleged Member
They sell hookups for the carter/edelbrock. In a pinch I hooked one up to the top of the linkage and pulled it forward to anything there it could be fastened to. I tried the thermostat hose clamp and it worked good.
:gwc: :gwc: :gwc: :gwc: :gwc: :gwc:
82 'ject is offline   Reply With Quote
Old 07-05-2003, 08:52 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Does this help? The adaptor should be in the carb box.
PS- I have discovered that the square bores carbs need this adaptor. This will keep the kickdown or TV cable fully extended at WOT.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-07-2003, 08:21 AM   #5
BigRed
Actually, this is a slightly old thread. I did rig the return cable up and have it routed forward instead of backwards like it was before. Thanks!
Scott Shelbourne
