![]() Join Date: Aug 2011
Hinge Bolts on Cab side question
Hello all, does anyone know of a company that would sell the cab side door hinge bolts? They seem to have a slightly thinner head than the normal bolts. It would be great to get them in stainless.
Re: Hinge Bolts on Cab side question
AD of TF? My TF bolts are standard flange head, 3/8 fine thread I think?
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
AD 49 maybe I'm losing it but those bolt heads on the cab are thinner than the hex head on the doorside which are standard thickness. Pat
Posted via Mobile Device |
Hollister Road Co.
You will need to go to fastenal or some bolt supplier. You could use a button head or low head cap screw or if you want hex then its a low profile hex but they tend to be very low and may be to low. Option 2 is if you know someone with a lathe to thin out regular Grade 8 bolts heads for you
Thanks all
