Old 01-31-2013, 06:31 PM   #1
EZ4U2C
EZ4U2C's Avatar
New Custom Dash
Here's my new dash. I custom made it and it has a curve outward to it. It's not the typical flat dash. I used Omega gauges. We also added the chrome tilt steering column.
God loved me so much he gave me John 3:16
Buy American and bring our jobs back home.
Trust what you believe in and believe in what you trust.
Don't blame the gun, Blame the person who made you use it!
1970 swb
2002 Harley Davidson Road King Classic
2004 Dodge 4x4
EZ4U2C is offline   Reply With Quote
Old 01-31-2013, 06:52 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: New Custom Dash
How did you make it? Are you an upholsterer?
Can't see the curve well enough to see if I like it but compared to the one I had on my 69 it's looks a lot better.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 01-31-2013, 07:41 PM   #3
seaflea
Re: New Custom Dash
Nice job!
seaflea is offline   Reply With Quote
Old 01-31-2013, 07:52 PM   #4
EZ4U2C
EZ4U2C's Avatar
Re: New Custom Dash
No its made out of aluminuml
1970 swb
2004 Dodge 4x4
Old 01-31-2013, 09:18 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: New Custom Dash
Cool!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-01-2013, 12:18 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Re: New Custom Dash
How in the world did you do that? From the pic it looks like it's vinyl coated or something.
06 Trailblazer
Old 02-01-2013, 08:27 AM   #7
mac808
mac808's Avatar
Re: New Custom Dash
Very trick! Subtle but stylish mod. Great job!
mac808 is offline   Reply With Quote
Old 02-01-2013, 08:34 AM   #8
EZ4U2C
EZ4U2C's Avatar
Re: New Custom Dash
No we painted with base coat clear coat then wet sanded it with 2500 and 3000. Then I buffed it till I seen myself
1970 swb
2004 Dodge 4x4
Old 02-01-2013, 11:27 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: New Custom Dash
So,, you used a solid bar of aluminum and milled/machined it? Still trying to figure out how you shaped it to fit.
btw: great job on guage panel and interior mods.
06 Trailblazer
Old 02-01-2013, 12:59 PM   #10
Madtat
Madtat's Avatar
Re: New Custom Dash
different- nice.
Madtat is offline   Reply With Quote
Old 02-01-2013, 02:22 PM   #11
AustinScott
AustinScott's Avatar
Re: New Custom Dash
Just to help... Original poster's "dash" statement is equal to your "gauge panel" statement
He is talking about his Gauge Cluster panel... not the dash pad in the picture;...
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
Old 02-01-2013, 02:48 PM   #12
Madtat
Madtat's Avatar
Re: New Custom Dash
Old 02-01-2013, 03:24 PM   #13
EZ4U2C
EZ4U2C's Avatar
Re: New Custom Dash
Yes you are correct it is my " gauge panel " some times I'm not politically correct
We made it from aluminum. The face plate is .125 thick and we cut the top and bottom returns on my cnc router. Then I mig welded the returns on. I took a old GAUGE PANEL and cut it out to where my new gauges would fit through. Then I bolted it from the back to hold the two together. Luckly we had the column out because it had to move foward about two inches to allow for the curve of the panel. We remove the chrome insets behind the headlight swicth and windshiled wipper, because with them on the arm on the headlight switch was too short. I left it short around the edges to allow me to use the factor screw holes. Hope this helps on how I did it. I have a template just case anybody needs one.
1970 swb
2004 Dodge 4x4
Old 02-01-2013, 06:50 PM   #14
68gmsee
Active Member
68gmsee's Avatar
Re: New Custom Dash
Originally Posted by AustinScott View Post
.......He is talking about his Gauge Cluster panel... not the dash pad in the picture;...
Now I understand!!! I noticed what looked like a slight curve on the dash pad so figured that was what EZ was referring to.
06 Trailblazer
