I'm ashamed to ask this but...
How do you swap an engine in a K20? Do you have to pull the transmission and transfer case out and then yank the motor or can the trans and T-case just be unbolted and slid back somehow? I've R&R'd the engine several times in my cars but never in a truck and and this SM465 and NP205 weigh a bunch more than a muncie. How do you guys prefer to do it?
Re: I'm ashamed to ask this but...
i just remove the bolts on the bellhousing and just pull the engine. thats the way i have done it with small blocks, big blocks mt favorite engines to work on, straight 6's
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
#3 | |
Assuming that they don't need any work, I leave the transmission/transfercase in place. It is much easier to remove the engine, leaving them in place.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right.
78K & 79C Jimmys
should come out like a car would,off from the tranny
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Thing about a standard is you have to lift the engine high enough to clear the mounts and slide it forward to get the in put shaft out of the clutch disc and pressure plate. I have unbolted the pressure plate if it has an inspection cover so that I only have to move it forward enough to get it out of the pilot bushing. I have also removed the mounts from the block to get enough room to move it forward. Depending on the clearance of the trans tunnel if may pick up high enough to move forward over the mounts.
Thanks guys. I didn't know if you could slide the engine off the input shaft of the trans or not. On my Chevelle and Camaro I can bench press the muncie on and off so its not a big deal but Im not tough enough for the truck pieces. So the trans and t-case will be ok with just the crossmember holding them up?
when i pulled a motor and left the tranny in i used a jack stand to suport the tail shaft and anything else that might pull down on the cross member. as a just in case sorta thing
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab dd
Dont be ashamed to ask questions around here lol! as for pulling the motor, i prefer to do it with the trans bolted to the motor however i have never done an engine swap on a 4x4, so i would imagine you would have to at least unbolt the t-case to get it out easily.
Cole. 1967 GMC c15 1991 k2500 2005 2500hd Duramax |
What Hump?
I agree with 92gmcdriver, never be ashamed, the only stupid question is the question that is never asked, this board is a give and take learning process.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
I've pulled mine in one piece before, motor, tranny, and transfer case. Get a transmission jack under the tail end of the transfer case, separate the crossmember from the frame and the transfer case, and remove it all as one unit. Keep in mind this takes at least two people. Leave your e-brake engaged, as well.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400
As you lift the engine use a jack under the trans and jack it up as high as it will go. It usualy bottoms out on the floor pan. This should get you enough room to slide the engine off of the input shaft.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
My B.I.L.s father told me about this over 20 years ago,pull front clip first,then engine or engine& tranny...way easier too.Been doing it that way ever since,just pulled a 6.2/400 combo last weekend this way.Was around 2 hours had front clip off,205 case pulled,then engine& tranny out.The older I get,this really works good!!
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution"
#13 |
Like Eyegore said,no dumb questions,how do you learn anything if you don't ask a question???
#14 |
And if I need to roll it or it will be out for an extended period of time I either use a welding rod/clothes hanger and wire it up to something on the firewall or if the frame is where I can run a 2X4 or long extension rail to rail (side to side) I will use 2 long bolts like a starter bolt with nuts on the back side to set it on or secure it to the 2X4.
#15 |
when i did my ramp truck swap for a 350 to a 454 all i did is in bolt the bell houseing start to pull the motor straight up till the trans is up against the floor put a jack under the trans and then pull motor forward. works so well, puting the motor back in takes a little wiggling of the motor to get it to line up with the imput shaft. if the motor its self in less then an hour spent more time geting tools crane (i used a wrecker with a boom for the in out of the boom) and making up the exhaust system. its the best way to do it if you are leveing the trans. also works on auto trans to just make sure the converter is all the way back+
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
#16 |
For my Manual Transmission truck, I found unbolting the transmission from bellhousing, then pulling engine/bellhousing, to work best
Then to put back in, I lowered the transmission, and put that in after the engine came back in Dont forget a jack stand on whatever you leave in! You dont wanna tweak your trans crossmember! |
| Bookmarks |
