S10 Gas Tank Solution
I didn't want my tank in the cab with me and apparently I have mounted my cab a little lower than I had anticipated. So, my S10 tank would not fit under my cab. To fix this, I ordered a 1965 Mustang 16 gallon tank and built a frame out of 1 1/2 inch angle iron. The bed support cross member was in the way to which I drilled out the factory rivets and flipped the cross member over. I did have to cut the cross member in half to remove it. Once installed I welded it back together after bolting it back in place. The tank clears the x member. All in all, it turned out better than I had thought it would. Now I can put my bed on for the final time. Not pictured is that I covered the original rear center filler inlet and moved it to the front corner behind the driver.
Re: S10 Gas Tank Solution
Well it looks fantastic.
Great Job! So where will the filler cap be? I want to take the tank out of my cab, but I really like having the filler cap right there on the cab corner. I know it's impractical, that's why I'm looking for other good ideas for mounting the tank. |
I'll get a shot of the new filler cap Friday.
![]() Join Date: Jan 2013
Man that looks really good. Almost looks factory, like it's supposed to be there. Good work!!
WWW.TASKFORCEERA.COM '47-'59 Chevrolet Truck Clothing |
Old Heap Driver
A friend of mine used a Mustang tank under the rear floor of his 51 delivery, fits like GM made it that way.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Did you use the Mustang sending unit? If so what gauges are you using? I have the same tank to install in my 51 and haven't decided whether to use the Mustang sending unit and try to find compatable gauges or put in the correct sending unit for the factory gauges.
I am using the Mustang sender and bought a Autometer #4315 gauge (Ford Specific).
Forgot to ask, what did you do for venting the tank?
I am using the S10 cap, it is vented.
I did the same thing but in the rear of the bed. Running autometer ford gauge and a really cool chrome flip top marine gas fill that is vented. Nice job never thought to mount in in the front of the bed. Are you running a drive shaft loop just for that extra safety, being over the shaft?
No loop, but it the d/s did come loose, the inverted cross member would stop it from hitting the tank.
