Old 02-01-2013, 12:27 AM   #1
78bronzechariot
78bronzechariot's Avatar
Pitman arm on 73-87 steering gear
The pitman arm on my '67 is wearing out. I believe the PO put a newer power steering gear on the truck because he cut the bumper bracket a little to make it fit. I just need to find out if I need to order a pitman arm for a '67 or for a newer truck? Are the spline counts the same between various years? Or is the length and/or the offset different on the newer trucks? Any help on which part to order would be appreciated.
78bronzechariot is offline   Reply With Quote
Old 02-01-2013, 12:30 AM   #2
bricalabro
Re: Pitman arm on 73-87 steering gear
Is it 2wd or 4wd
The taper on the centerlink on 2wd is the same. Order a moog pitman arm for the year of the steering box
bricalabro is offline   Reply With Quote
Old 02-01-2013, 12:32 AM   #3
78bronzechariot
Thanks for the quick reply, I am not sure what year the box is, as far as i can tell from pictures they all look the same. Do you know any defining feature or casting number? Thanks
Old 02-01-2013, 12:46 AM   #4
bricalabro
I'll have to double check the book tomorrow. But I'm almost 100% sure it's the same from 73 to 85. If its pwr steering variable ratio. K6143 moog
Old 02-01-2013, 12:50 AM   #5
78bronzechariot
It is 2wd and thanks for your help
