Control arm bushings
I need to rebuild my front control arms. What do you guys think- keep the existing steel bushings or go with the later model '73-87 rubber bushings? Which are better?
Re: Control arm bushings
I changed my front end to 76' and then rebuilt everything.
FYI; the control arm bushings are tuff to get out.... I did not have a press, so I torched the rubber then push them out! kind of messy but it worked!
People who make excuses didn't want to do it in the first place! ![]() http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I prefer the '73-'87 rubber bushings. The steel bushings need to be greased, otherwise they start to squeek.
Watch out for your cornhole !
![]() Join Date: Jun 2003
When I built my 63 I ran the costs to rebuild my original arms versus the 73-87 arms. The later arms are much cheaper to do. I used later arms with an Energy Suspension urethane bushing kit from Summit for like 70 dollars versus having to buy the steel bushing kits which were something like 3 times that amount for the original arms.
Cool guys. I decided to go with the later arms and bushings. Buy once, cry once.
![]() I wonder if there's any noticeable difference in ride quality between the two bushing types? Probably minimal eh? |
I also changed to rubber bushing. Go to Youtube and sreach for "contrl arm bushing replacing" , this guy cut the inner tube with hacksaw and using a long screw and 3inch. pipe, he pushed the bush out. To install, he reverse the pipe and long screw. Bets paying more then $200 at Brake shop.
Who Me?
I went with original bushings when I rebuilt my front end. It was just easier that way for me.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
![]() Join Date: Mar 2011
Not trying to hijack the thread but I replaced my bushings with the original style steel ones and now I can't get them to take any grease. I've tried several different approaches. Anybody have similar problems and if so what solution did you come up with?
