69 Suburban C20 Lowering Help
I'm new to the forum,looking for information on a 69 Suburban C20
Can any one help me figure out the best way of lowering a C20 Suburban Not looking to go the airbag route. Will it be harder to lower it because it's a C20 VS C10?? Pictures of your truck and kit used would be GREAT. Any and all help would be appreciated Thank you |
What?
Re: 69 Suburban C20 Lowering Help
Welcome to the forum!
I am of no help on this subject, but I am sure someone will chime in shortly.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#3 | |
Junior Member
Welcome to the board! Post some pics of your burb!
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 02-01-2013 at 05:04 PM. Reason: add info, pic |
Thank you guys.
This is how it looks now. I think it used to belong to Tom on this board. |
What?
Very nice!
What ever you do, don't chuck those wheels and caps! They may not be worth a ton of money, but guys out there like me would like to see them saved for the guys n' gals building OE style rigs.
Price goes up in spring > been watching it on kijij for months think they started at $10995 ?
There basically the same as far as suspension design. Same frames 1/2 and 3/4 ton. Not hard just more expensive depending how low you want it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Thanks for all the info
I want a kit that lets me keep the truck as original as possible. So no C-notch for me. Disc brakes and 5 or 6 lug conversions are ok. Keeping this in mind what is the lowest I can go, and with what kit? Posted via Mobile Device |
Junior Member
Super sweet burb. It is going to look great closer to the ground. You do not have to c-notch with a 4.5/6 drop. I did mine but it is not necessary.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 02-02-2013 at 09:35 AM. Reason: add info |
Looks like I will be going with ECE 4/6 drop,with the Front disc conversion kit. Now I need help with the rear end. What rear end can I use to swap to a drum 5 lug setup? |
call bills truck shop 905 725 3460 he is in courtice should have a 71-72 rear end there. you can also use a 67-70 (6 bolt) and put 5 bolt axles in it from moser.
Ugh, I would love to have a c20 burb. Send that down to me and get a c10 burb and lower it instead.
Done now, LOL.
04 Yukon XL 2500 w/ Quadrasteer ![]() 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
#12 | |
