Old 02-01-2013, 06:46 PM   #1
Buckthetruck
Turn signal cam removal
I have a new turn signal cam to install, but the old one will not come out. Is there another screw holding it in that I cannot find? Looking at the new one, I expected it to just slip off and the new one go in. But it does not want to come off.
Buckthetruck is offline   Reply With Quote
Old 02-01-2013, 07:07 PM   #2
Buckthetruck
Re: Turn signal cam removal
Ok, I pulled the whole assembly out and found the holding screw. Now that the new one is in, the rear signals work easily, but the dash signal and front signals don't work unless I push the lever up a little beyond the catch. Any suggestions on adjusting this so it works right? Thanks
Old 02-01-2013, 11:09 PM   #3
62ss409
If I remember correctly, I had to bend the horseshow shaped spring a little bit more towards the centre. Slightly, only
62ss409 is offline   Reply With Quote
