Old 02-01-2013, 07:13 PM   #1
joe750
joe750's Avatar
adjustable panhard bar for bagged '66
I plan on bagging the rear of my '66 in the next few weeks with a simple bolt on c-notch.
Already have Dominator 2600 bags and viair compressor.
Now I'm just getting all the other odds and ends before I start.
My question is... will the CPP adjustable panhard bar work with a bagged system?
Wouldn't you have to adjust it if you were going to ride around with it raised or lowered?
'66 c10 LWB fleetside 250 I6 3 speed on column
'65 c10 LWB stepside 350/327 3 speed hasn't moved in 10 years. Just rotting away
joe750 is offline   Reply With Quote
Old 02-01-2013, 07:26 PM   #2
LVPhotos
LVPhotos's Avatar
Re: adjustable panhard bar for bagged '66
I had mine cut to their advertise length after getting 4 the wrong size. For the ladder frame there is a couple to choose from. One bent for axle room. Mine works fine with adjustment at half Max adjustment. As it sits the bar is parallel to crossmeber and ground.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
