Old 02-01-2013, 09:07 PM   #1
Sterling
Fuel Gauge Problems, need some help
Hello guys,
I have dual gas tanks. Here is my situation
Full to the rim, the Right hand tank when selected reads just at about HALF tank. Then it reads going down from there. Reads about the dash after empty at half tank, and really doenst go down farther from there, Ive gone to about 16/20 gallons used, but I dont dare go further to run risk of running a diesel dry.
Now the left tank (drivers side) reads about a half inch past the Full line , but doesnt move at all
I have a feeling the left tank has a ground issue with the sender, and I feel the sender or float is bad on the right.
Am I close? or has someone experienced this before and knows better?
I want to tackle 1 tank at a time, I can atleast drive it with one tank off. But want to have parts ready
-Sterling
Sterling is offline   Reply With Quote
Old 02-02-2013, 09:03 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Fuel Gauge Problems, need some help
over full sender off
E short
inbetween ...ground
I'd work over the switch/grounds
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-02-2013, 12:54 PM   #3
hatzie
Moderator
hatzie's Avatar
This assumes this is the 1982 truck you've posted about... 1973-1980 are different.
It's probably the senders but...
Test the gauge first. It's easy to test and easy to change.
You'll need
  1. A multi-meter.
  2. A Radio Shack 100 ohm volume control potentiometer
  3. Alligator clip test leads.
  4. Several Male Delphi WeatherPak terminals. The connecting wire gauge doesn't matter these are to hook test leads to WeatherPak plug sockets without damaging them ( I keep a handful of mating connector pins in 40 mil plastic baggies for various connector families in my meter bag ). Delphi Male WeatherPak Terminal #12124582, 12089040, or 12089307
Follow these instructions from the Corvette guys to build a cheap Potentiometer fuel gauge tester... Note: Our 73-91 gauges are 0-90ohms like the C3 not 0-30ohms like the C1.
http://www.lbfun.com/warehouse/tech_...lGaugeTech.pdf
  1. Clip the leads from your fuel gauge tester to your multi-meter and set the POT to 45 ohms.
  2. Unplug the tank selector valve on the RH frame rail.
  3. Insert one male terminal in socket B of the wiring harness plug you just removed from the valve.
  4. Turn on the ignition. The fuel gauge should be pinned at 3:00 or close to it.
  5. Clip a test lead from a frame ground to the terminal in socket B. (this wire goes to the sender terminal on the gauge). The gauge should go to E.
  6. Unplug the ground from terminal B and sub one leg of your tester. Clip the other leg of the tester to the frame ground. The gauge should read @ 1/2 tank.
  7. Set the POT to 90 ohms and re-install on the valve plug as before. This will set the needle at F.
  8. 29 ohms is 1/4 and 64 ohms is 3/4....
If the gauge reads wonky check the wire from the firewall bulkhead plug under the brake booster to the valve plug for damage. Replace the gauge if the wire checks out.
You can check the senders at Full without removing a tank as follows.
  1. Fill the fuel tanks.
  2. Pins A & C of the tank valve plug are from the senders... insert Male weatherpak test pins in socket A and C.
  3. Attach one meter lead to the frame ground used in the gauge test and attach the other meter lead to pin A or C.
  4. Check each sender resistance with your meter set on 1K scale. It should be @ 90 ohms.
  5. If a sender reads open or too high check that tanks' frame to sender ground.
  6. If the sender reads too low then it's probably just bad.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Last edited by hatzie; 02-03-2013 at 01:14 PM. Reason: Correcting my poor grammar.
hatzie is online now   Reply With Quote
Old 02-02-2013, 09:40 PM   #4
Sterling
Thanks Hatzie, Ill drive my truck over to our heated warehouse (its around 0 F outside) and give those tests a try. Updates to follow
