Old 02-01-2013, 11:22 PM   #1
trivon56
trivon56's Avatar
Under dash wiring
Has anyone one this site post any threads on how to rewire your truck or how to wire under the dash. My wires melted and need replacing. And also any budget friendly ideas on how to fix the issue.
trivon56 is offline   Reply With Quote
Old 02-02-2013, 01:22 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Under dash wiring
Junk yard if your lucky
search /read the wire diagrams
pull out the bad, label as you go
then you know what to grab
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-02-2013, 01:34 PM   #3
hatzie
Moderator
hatzie's Avatar
Wiring diagrams are in my sig.
How to fix depends on how roached the harness is.
If it's 3-5 wires then solder and heat-shrink one at a time till the damage is cut away and repaired.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
hatzie is online now   Reply With Quote
Old 02-02-2013, 02:03 PM   #4
Sabaka454
Sabaka454's Avatar
hatzie - Did you scan all of those yourself? That's a lot of scanning lol Great of you to share those. I have them in my library and often thought of scanning mine but it seems you've beat me to it.
trivon56 - the first thing I would question is why your wires melted before you simply replace them. Did you bypass your fusible links?
Sabaka454 is offline   Reply With Quote
Old 02-02-2013, 02:27 PM   #5
trivon56
trivon56's Avatar
I am not really sure. The guy left a lot of things wired hot and then used speaker wire. The under dash was just all messed up. It ran for awhile and then one day the battery died and then I charged the battery. After I charged the battery I started the truck it ran and once I cut the truck off it kept running. I finally made a mistake and shorted my battery and it cut off. I knew earlier when it wouldn't start I smelled something burning in the cab or it smelled like something burned. I then looked under the dash and saw all the wires melted. Not the best of days.
Old 02-02-2013, 02:48 PM   #6
hatzie
Moderator
hatzie's Avatar
All 37,000 pages. 12x34 Sheetfeed and 4 core processors are a wonderful thing. Never would've done them with a flatbed.
Geez. Ain't previous owners fun? Sounds like they butchered the engine harness by bypassing the Fusible Links too. I'd Start yard picking for a rust bucket with a good harness.
Old 02-02-2013, 03:32 PM   #7
trivon56
trivon56's Avatar
He did a real hack job on the wiring. I hate half ass work.
Old 02-02-2013, 04:35 PM   #8
hatzie
Moderator
hatzie's Avatar
That's painful to look at.
Some folks should have their tool box card revoked.
Old 02-03-2013, 01:26 AM   #9
slam59
I am going thru the same thing with my truck. Wires melted together I will go to the yard and pull a harness fr a truck there Xmas have my mechanic rewire it for me. I smelled burnt wires on way home one day. Previous owner did some funky stuff under my column as well.
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
