Old 02-02-2013, 03:45 AM   #1
1970greenburb
Panhard bar
Can anyone tell me if you use your stock bracket for the panhard bar on the frame and just change location on the rear axel.
1970greenburb is offline   Reply With Quote
Old 02-04-2013, 05:07 PM   #2
1970greenburb
Re: Panhard bar
Hello again haven't heard anything yet. So maybe I am saying it wrong. Do you use the stock location on the frame and change the one on the axle for the pan hard bar or do you leave the one on the axle and change the frame one, when lowering a suburban.
Thanks in advance
Old 02-04-2013, 11:20 PM   #3
gumbys10
Re: Panhard bar
I recommend getting a adjustable one from a source like LMC trucks or the like, should have an adjustable bushing sleeve on both sides, so you can centre the axle. You do not change the mounts.
gumbys10 is offline   Reply With Quote
Old 02-05-2013, 12:55 AM   #4
1970greenburb
Re: Panhard bar
Thanks Gumbys10 , I bought a adjustable one at a shop near me called Dreamers I was just wondering about the mounts look like it would hit once it was lowered.
Thanks again.
Old 02-13-2013, 01:43 PM   #5
RWB-713
RWB-713's Avatar
Re: Panhard bar
Relocating the axle mount to the right side trailing arm is highly reccomended to correct the angle of PH bar & for clearance issues when lowering. Check out ECE's "super track bar" kit.
http://www.earlyclassic.com/catalog.aspx?category=super track bars
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold ***
First Ride <> '81 C10 Long Fleet *** Current Project ***
RWB-713 is offline   Reply With Quote
