Firewall pad
Firewall pad;
What is the trick to getting these plastic fasteners pressed in? I have broken a few already Posted via Mobile Device
People who make excuses didn't want to do it in the first place! ![]() http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16 |
Re: Firewall pad
I made a tool to slide inside. The tool is just a rod that goes in the hole with a washer welded to it. And I put a little lube on the tip before driving it in.
Re: Firewall pad
I threw mine in the garbage and bought some more flexible ones at the local auto parts store.
I Got it BAD!
Re: Firewall pad
Don't use the plastic ones. LMC has the rubber ones...
Then use a pushrod from a smallblock. The rounded end keeps the tip from pushing though the fastener. I put a few drops of oil on the pushrod to make it easy to slide into the fastener.
Build Thread: http://www.chevyguys.com |
Re: Firewall pad
Hey thx fellows I just noticed today that LMC had the rubber ones, as you mentioned!
I'll order up some of those, surely they we'll go in easier! Thanks again! Posted via Mobile Device
