Old 02-02-2013, 11:14 AM   #1
HOTFUN
HOTFUN's Avatar
64-66 hubcap: can clip ring be removed?
I thought I read somewhere that the ring installed inside the 64-66 clip style hubcaps can be removed and used for a the wheel nub installation. I know recently there was a thread on installing these rings by cutting one out of a dented up original and installing in a reproduced cap? Anyway I have a NOS 3/4 clip type cap like in the picture below that I appreciably borrowed from a search. Can the ring be carefully trimmed out and a useable lip still be present? Otherwise anyone happen to need a trade?
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 02-02-2013, 11:43 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 64-66 hubcap: can clip ring be removed?
For 15" or 16" wheels with clips. Last listing on the page.
Old 02-02-2013, 02:33 PM   #3
HOTFUN
HOTFUN's Avatar
Right 7 5/8th inside of the steel insert but if the steel ring was removed or trimmed back to near the chrome outer edge it would be the correct 10 3/16ths inch width to fit over the wheel knubs. I have laid them side by side and they are outside identical and the same size just that the metal ring was installed inside for the clip style wheel mount. I hate to cut it up but it would be nos and undetectable once it was installed on the wheel.
'72 GMC K2500 4x4
Old 02-02-2013, 03:54 PM   #4
60-66
60-66's Avatar
I have removed the ring from this size hubcap before to put in a larger ring for 3/4 ton trucks but I would NOT do that to use these on a half ton NUB style wheel, I think it would fall off pretty easy, I dont feel theres enough material on the edge and it would be tough to roll the edge correctly to keep them on the wheel. The lip can be peeled back and then pull out the insert ring, in fact I did it to the caps on the K20 in my Avatar. Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-02-2013, 06:13 PM   #5
HOTFUN
HOTFUN's Avatar
Hi Jon, I was thinking the same thing but I thought if I left a 1/4 inch portion of the metal ring I might be able to bend a lip with it to add strength to that rolled edge. May not be worth it as I have two NOS chrome 1/2 t knub caps and this one NOS clip style so I should just keep looking for two more before I destroy this one. Thanks, Mark
'72 GMC K2500 4x4
Old 02-03-2013, 04:13 AM   #6
rideblue00
rideblue00's Avatar
I did that to my 3/4 ton cap (pull out the ring). I carefully bent the chrome cap open just enough to pull the ring out. I dont feel there is enough metal to bend back over far enough to get that 1/2 ton cap rolled edge for the nub style. I took mine out in order to install clips on a newer 88-98 8 lug rim. Its going to work, just have to finish the project.
rideblue00 is offline   Reply With Quote
Old 02-03-2013, 12:05 PM   #7
HOTFUN
HOTFUN's Avatar
That picture answers my question. Thanks everyone.
'72 GMC K2500 4x4
Old 02-03-2013, 12:28 PM   #8
SFTorange
SFTorange's Avatar
I'll second everyone's responses. I cut the ring out of a 3/4 ton cap, leaving about 1/4 inch around the perimeter. I then used pliers to roll the extra metal down as is it is on the 1/2 ton caps. It fits pretty well over the nubs on my wheels, but I wouldn't trust it given that I can't keep the 1/2 ton ones from falling off occasionally.
The Brown Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=437222
SFTorange is offline   Reply With Quote
