Old 02-02-2013, 01:50 PM   #1
cfan10
cfan10's Avatar
Cool Bad Carb? 1406
Ok, lately I’ve been yard running my truck. But before it starts each time I’m having to dump fuel in the carb and then it turns over on the first try. I know the timing is off, and it runs loud because of the exhaust manifold. Does this sound like the carb needs rebuilding, because it has always been turn key.
84 c10
305 v8
Edelbrock 1406
Straight duals (passenger side manifold is only connected to exhaust pipe by one stud)
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 02-02-2013, 03:58 PM   #2
80SPORT
80SPORT's Avatar
Re: Bad Carb? 1406
This is a common problem on older trucks
Check for cracked fuel line on the suction side between the tank and the fuel pump
What happens is it sucks air instead of fuel
If you prime the carb and get it running it will keep going
Try hooking a small tank directly to the fuel pump;if that cures it replace the fuel lines....not an easy job as you have to pull the box or the tank
80SPORT is offline   Reply With Quote
Old 02-04-2013, 10:46 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Bad Carb? 1406
yup,might even see vapours from above,I did,
mine got stoned lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-05-2013, 01:24 AM   #4
cfan10
cfan10's Avatar
Re: Bad Carb? 1406
Fairly new sending unit and fuel lines, but I will take a look to be sure. Thanks, guys.
