Old 02-02-2013, 07:03 PM   #1
72restorationvirgin
Active Member
72restorationvirgin's Avatar
New Hood to Cowl Seal/Raised Hood
I know there are several threads on this but I just installed a new cowl seal and stainless trash guards. I know some say to try new hinges and springs but I press down on the back of the hood when it's closed with all my weight and it still doesn't go flush. Will new hood hinges and springs really be strong enough to hold it down or make a difference? I tried adjusting the hood hinges but it make's no difference. It doesn't help I got the POS LMC cowl seal.....
So should I just try to get a new seal from a vendor (Classic HeartBeat) or try new hood hinges/springs???
67 C20 283/4 Speed
72restorationvirgin is offline   Reply With Quote
Old 02-02-2013, 08:20 PM   #2
asolde
asolde's Avatar
Re: New Hood to Cowl Seal/Raised Hood
Your hood to cowl seal should be a V shaped seal not L shaped. Rock auto has the correct seal for our trucks.
asolde is offline   Reply With Quote
Old 02-02-2013, 08:26 PM   #3
AirSpeed
AirSpeed's Avatar
Mine did the same thing, I just took it off. I can't see any real need for it anyway, unless it does something I haven't thought of?
AirSpeed is offline   Reply With Quote
Old 02-02-2013, 08:31 PM   #4
leddzepp
Moderator
leddzepp's Avatar
You can bring the back of the hood down by adjusting the hinges. Open the hood, loosen the hinge bolts that attach to the fenders. Then, push the hood further up to rotate the hinges back. Tighten the bolts, keeping the hinges in that position (it is easier to do this with two people, so you can hold the setting) Close the hood carefully...you will see that this "pulls" the back of the hood down when shut. If you over adjust, the hood will scrape the cowl, or go down too far past the cowl. If you play with this adjustment, you can dial it in.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-02-2013, 08:39 PM   #5
72restorationvirgin
Active Member
Ok I'll try adjusting it again. Thx
67 C20 283/4 Speed
Old 02-02-2013, 09:01 PM   #6
AirSpeed
AirSpeed's Avatar
I tried to adjust mine as you describe with no luck, I'm thinking my hinges or springs are worn out. Would that be the problem? I don't see and wear but can't really test the springs.
Old 02-02-2013, 09:07 PM   #7
72restorationvirgin
Active Member
Well I'm no expert. That's just what I read in some past threads but I have no clue.
67 C20 283/4 Speed
Old 02-02-2013, 09:14 PM   #8
AirSpeed
AirSpeed's Avatar
I noticed the brace the on the hood where the hinges mount flexes a lot while opening and closing the hood, I wonder if the brace has bent over the years? My 72 hood fits flush, that's without the seal, my 69 sticks up in the back without the seal. The hinges in my 69 don't seem to have any play and the springs seem strong when opening the hood. I have the hinges all the way down as well. When I repaint the 69 I'm going to try to mess with the brace and see if I can get the hood to seat.
Old 02-02-2013, 11:04 PM   #9
jhwkns
Registered Cruiser
jhwkns's Avatar
When it's cold out, try relaxing the seal with a heat gun. This works for door seals too.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 02-02-2013, 11:33 PM   #10
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
X2. Had same issue with mine. Need to take time to adjust hinges. Be patient and get the help of someone.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-03-2013, 09:07 AM   #11
Sammy
Adjustment is first option of course. But elongated rivets in the hinge can cause this also n very hard to see. Using the correct seal then the adjustment on the hinge is the first two steps.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-04-2013, 03:45 AM   #12
72restorationvirgin
Active Member
Anyone know the point for the hood to cowl seal??? Does it matter if it's on or off???
67 C20 283/4 Speed
Old 02-04-2013, 05:35 AM   #13
hilljob26
hilljob26's Avatar
i think it is just to minimize the elements from getting through
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-04-2013, 06:01 AM   #14
SS Tim
SS Tim's Avatar
It is to help prevent engine compartment fumes from entering the cabin air intake plenum.
SS Tim is offline   Reply With Quote
Old 02-05-2013, 01:20 PM   #15
RenoKeene
Florida Edition
RenoKeene's Avatar
I think this is a common problem on these trucks. My hinges are adjusted as far as they go and are solid pieces, the seal is NOS so the only cure on my truck is to elongate the holes in the hinges.....someday, but its ok for now.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
