Old 06-12-2003, 05:21 PM   #1
ginter
ginter's Avatar
Rear wheel bearings
Any suggestion for pulling the seal, bearing and outer race? Specifically I guess the most difficult part would be the race. My left side bearing is completely trashed and the truck is down.
TIA
72 1/2 ton LB, leafs, 12 bolt open
ginter is offline   Reply With Quote
Old 06-12-2003, 05:50 PM   #2
Gene
Gene's Avatar
Yep, pull the axle out, rent a bearing puller and tap the new one in. Pretty simple, I did mine about a year ago.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 06-13-2003, 08:51 AM   #3
Mike C
Mike C's Avatar
I did gears in an 87 Blazer about a year ago. The bearing races and actually galled into the housing. I break the slide hammer puller and never budged it. I was fortunate that I had the diff out, and used an 8' piece of black pipe from one side, through the diff, and up to the race, then beat the crap out of it with the proverbial BFH. Hopefully yours comes out with the puller...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-13-2003, 09:11 AM   #4
tom hand
CCRider
tom hand's Avatar
Well here's a little trick...if you have access to a welder, weld a bead all the way around on the face of the race. It will "shrink" the race and it come out very easy. Be sure to stuff wet rags in the axle tube, and protect the area in front of the race with heavy tape or anti-splatter spray. Works like a charm.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
