Old 02-02-2013, 09:55 PM   #1
kwin
kwin's Avatar
Suburban Question
I am about to embark on the cummins suburban project, I have a 3/4 ton burb but the body is rough, very rough. I have a few 1/2 tons one has a decent body but i'm not excited by a body swap considering everything else thats involved.
Here is the question! How rare are the 3/4 tons? Is this going to be a needle in a hay stack?
I assume the 1/2 ton frame is going to be too light, would you diesel guys concur?
Thanks for your time.
Keith
Keith Winsor
www.ramsaywinsor.com
kwin is offline   Reply With Quote
Old 02-03-2013, 01:46 AM   #2
mr.chevyblack
mr.chevyblack's Avatar
Re: Suburban Question
what year is the 1/2 ton ones the 89-91 are probley the strongest 1/2 ton years
mr.chevyblack is offline   Reply With Quote
Old 02-03-2013, 01:07 PM   #3
Mr. 250r
Mr. 250r's Avatar
A 3/4t suburban is quite common unless your looking for like a 91 then its a little harder or maybe its just my area but i still say they are pretty common as far as the frames they should be the same 3/16in thick will the 1 tons i think are a 1/4in thick and taller now although its been awhile since i measured a trucks frame thickness i believe thats correct also the springs and axles will change obviously
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 02-03-2013, 01:23 PM   #4
vegadesign
vegadesign's Avatar
From my experience in the diesel industry, the 1/2 ton frame can handle it with a couple mods
Boxing in the front of the frame will help drastically.
What's the plans for the diesel?
You said cummins so I'm assuming its a 12v?
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 02-03-2013, 03:13 PM   #5
kwin
kwin's Avatar
ya its a 12 valve with , he351, aftermarket injectors ( cant remember the size) Pump mods including fuel pin. i built it a few years ago for my Wide track Cherokee, and so many parts of the cherokee were lost in a fire it does not seem realistic to start over.
My buddy is a diesel specialist he has a first gen making over 750 hp, he figures in the 400 hp area.
The one"nice" burb that I have is a 1989 1/2 ton, very little rust other than the barn doors are shot.
I would be willing to use it if the hunt for a 3/4 ton does not work out.
Keith
Keith Winsor
Old 02-03-2013, 04:34 PM   #6
vegadesign
vegadesign's Avatar
Sounds like a fun build, my buddy built his 72 with a 12 valve first gen with about 700hp and got about 50 mpg
Good luck with the 3/4 ton
I would just work with what you have and beef up the frame
Old 02-03-2013, 10:07 PM   #7
kwin
kwin's Avatar
I plan to run veggie oil, I'm planning for extra fuel tanks and a long range. if I get 25 mpg I'll be thrilled!
Keith Winsor
Old 02-03-2013, 10:07 PM   #8
kwin
kwin's Avatar
They make canola oil up here I should be able to get waste easily.
Keith Winsor
