02-03-2013, 01:43 AM | #1 |
A guy with a truck
Fuel Sender Wire Firewall Pass Through?
Where is the correct spot? Mine is snuck through by another grommet, obviously in the wrong spot. There is a small grommet on the wire near the fusebox end, but I don't see a hole for it anywhere. Where is it supposed to exit the cab?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-03-2013, 10:39 AM | #2 |
Re: Fuel Sender Wire Firewall Pass Through?
To the right of the fuse box connecter, there is a vertical row of five dimples, s/b the second one down
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-03-2013, 11:24 AM | #3 |
A guy with a truck
Thanks, I'll look for it. In the engine bay, or inside? Any idea on hole diameter in case I need to drill?
02-03-2013, 01:37 PM | #4 | |
Look in the engine bay side, easier access....
02-03-2013, 06:07 PM | #5 |
A guy with a truck
Can anyone confirm this location before I break out the drill? Wonder what happened here? Maybe it's a Friday truck
02-03-2013, 08:32 PM | #6 |
That grommet in the rug pic is what is supposed to be in the firewall
And no, it is supposed to be one dimple up Bottom dimple is for the tach wire
