Old 02-03-2013, 03:16 AM   #1
85burb
85burb's Avatar
Help finding tapping noise.
It is not a ls swap but it is a ls problem. It is a 4.8 in a 07 chevy. It sounds like it has a bad lifter. Like when the roller fails. Well any ways i pulled heads and came and lifters out and everything looks great. The only thing i seen is there is a interesting patteren of the base circle of the cam. Any ideas? Noise comes and goes. It can run a while without it and then it has it at start up and all the time later. Motor has over 272xxx on it. Has almost 40 psi oil pressure hot. I was for sure it was a lifter issue from the noise. I really need help on this. It is a shop truck and me and a guy that worked at chevy were sure it was a lifter. So i ordered all the stuff to do a cam and lifter job. Over a 1000 bucks. My boss is not mad but i feel like a idiot. Thanks!
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-03-2013, 10:33 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Help finding tapping noise.
I had a belt tensioner sound similar to that on my 4.8, I knew it wasn't the lifters when it started squeaking tho.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-03-2013, 10:34 AM   #3
Clyde65
Clyde65's Avatar
Btw, for $1k you could have bought a take out and dropped it in.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-03-2013, 10:40 AM   #4
85burb
85burb's Avatar
Yes I know we could have got a motor. But our general manager won't buy stuff on line. Hell we could have found a 5.3 for that. When I was looking fore the noise I put a pry bar on to head and exhaust manifold and I clearly heard the noise in cylinder 1 exhaust port area.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 10:44 AM   #5
Jon01
Jon01's Avatar
Did you check pushrods for straightness?
Jon01 is offline   Reply With Quote
Old 02-03-2013, 10:54 AM   #6
85burb
85burb's Avatar
Not yet. They all look fairly strait when I removed the
Will check today.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 10:57 AM   #7
Jon01
Jon01's Avatar
I doubt any are bent unless it's really had it's neck wrung but it's an easy check while you're in there and will give noises like a lifter tapping.
Old 02-03-2013, 11:19 AM   #8
whitels1
whitels1's Avatar
It's normal for LS engines to sound like sewing machines, and that's what it sounds like. If you didn't see any excessive wear on the cam the crank should look similar. Maybe try a heavier weight oil.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 02-03-2013, 11:23 AM   #9
Jon01
Jon01's Avatar
They are noisy but that is excessive. Even with 200+k on it it should not be clattering like that.
Old 02-03-2013, 12:26 PM   #10
85burb
85burb's Avatar
This noise is not normal. Some ware there is something not working right. I have 2 in personal trucks and like 6 at work and they are all quite except this one.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 03:30 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Ya thats not normal....even with dual springs and a high lift cam my valvetrain doesn't sound like that.
I'd also be interested in pushrod straightness....I know when you run a pushrod that is too long or too short in these...they sound like a Singer Machine, so I can believe that a bent pr could make the same. Did it change with rpm at all before you tore it down?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-03-2013, 03:33 PM   #12
85burb
85burb's Avatar
Push rods are all strait. Yes if I revved the motor up the tick got faster. It is a factory untouched motor.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 03:36 PM   #13
orngsikL
orngsikL's Avatar
is it castech heads? head could be cracked. truck loosing coolant mysterously? any white smoke out the tail pipe at start up?
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 02-03-2013, 03:37 PM   #14
85burb
85burb's Avatar
No major coolant loss that we know of. It is a quart or so low. No smoke
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 03:44 PM   #15
orngsikL
orngsikL's Avatar
did the underside of the valve covers look like butterscotch pudding?
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
Old 02-03-2013, 03:45 PM   #16
orngsikL
orngsikL's Avatar
got these marks on the heads?
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
Old 02-03-2013, 03:47 PM   #17
orngsikL
orngsikL's Avatar
http://ww2.justanswer.com/uploads/Bl...t_loss_5.3.pdf
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
Old 02-03-2013, 04:05 PM   #18
Jon01
Jon01's Avatar
It shouldn't have 706's being an 07 thus no Castech issue.
Old 02-03-2013, 06:31 PM   #19
85burb
85burb's Avatar
The inside of the valve covers look like golded brown normal color. They are 243 heads if i remember. They are for sure not 706 heads.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 06:58 PM   #20
Jon01
Jon01's Avatar
Should be 243's or 799's in 07.
Old 02-03-2013, 06:59 PM   #21
85burb
85burb's Avatar
For sure 243 then.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-05-2013, 11:39 PM   #22
coyotes33
coyotes33's Avatar
Did you ever figure out the issue? The 5.3 that I just put in my 84 sounds the same
coyotes33 is offline   Reply With Quote
Old 04-05-2013, 11:50 PM   #23
85burb
85burb's Avatar
Yes and no. Yes the noise went away after the cam and lifter oil pump swap. No i never seen exactly what was causing it. I just figured it was a bad lifter. May thousand miles on that motor now and no more noise. Looks like you may be needing a cam swap soon.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-06-2013, 12:22 AM   #24
coyotes33
coyotes33's Avatar
What do you think?
https://www.youtube.com/watch?v=7Xmh...e_gdata_player
Old 04-06-2013, 09:12 AM   #25
85burb
85burb's Avatar
They sound the same. Have you looked under your valve covers? When I put my burbs motor in a push rod jumped out. Maybe take your belt off too and run it. Do you have good oil pressure?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
