06-12-2003, 06:10 PM | #1 |
Livin' it up.
Axle swap help.. 2wd 3/4ton with coils
Ok fellas as it seems i'm driving a LONG distance i thought that swapping out my rear end might be an option. As it sits now i've got that nice HO72 rear with 4.10 gearing... so mileage isn't happenin' even for a BB (yeah i know 'mileage' is never an option)
Anyone out there know what i can put under the rear of this thing EASILY with TALL, numerically low, gears.. i'm not talking 3.73 or something i mean low 3 or somethign in the 2s... this truck is not gonna need the torque as the motor more than has that covered. Suggestions greatly appreciated. Thanks Greg
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
06-12-2003, 06:48 PM | #2 |
Fabricate till you "puke"
you might do a search in eng& driveline, there was a post a while back on the dana 61(found in some Ford trucks), that would be around 3 to 1 gearing. It would be a weld in swap tho....good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-12-2003, 07:36 PM | #3 |
its all about the +6 inches
As far as afordable bolt in...I think you are about as good as you'll get.
I'll trade you for my 4.56 rear. |
06-12-2003, 10:06 PM | #4 |
Livin' it up.
rats... not what i was hoping but thanks guys
06-13-2003, 05:38 AM | #5 |
Livin' it up.
ttt any other suggestions? i'd really rather not run this motor at 3000+ for 2500 miles...
thanks
06-13-2003, 08:41 AM | #6 |
35" tires will fit in the back with no lift...
For bolt in 8 lug, Dana 60 coil with 3.54 is out there, but you probably should have been looking for awhile... Another option would be to swap in a 12 bolt with 3.07 and just throw the HO52 in the bed. Make sure and get a 6 lug spare to go with your 8 lug, however. Rumor has it that there may have been a lower 3 series HO52/72, but no confirmations. ANd obviously that will be hard to find.
06-13-2003, 12:51 PM | #7 |
Livin' it up.
hmm so the C10 axles will pop right in there huh Mike? i was wondering on that one and that way i'd just toss my old axle in the back.
Anyone know of any differences between the fittament of the C20 and C10? It'd probly be easier and cheaper to pick one of those up if the fit is a swap. thanks all
06-13-2003, 01:55 PM | #8 |
HO52/72 axles would take an older 3.73 gear set about 1000 years ago, but that's the lowest in gear reduction you could go. They're rare, and almost impossible to find so I wouldn't bother. 3.90 is the lowest you can go in those axles right now, and that's off-the-shelf new for around $250 uninstalled.
I've been salivating over the aftermarket Dana 60s that are out there....I'm saving my $$$.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
06-13-2003, 03:44 PM | #9 |
The only real issues I see is the bore diameter of the brake wheel cylinders and the length of the back half of the driveshaft might be different. But running through a parts store catalog should be able to turn up wheel cylinders with approximatly same diameter as the HO. Get the driveshaft from the donor truck you get axle from.
Cobalt, why an aftermarket 60? They are reasonably easy to find original ones. I have 3. One in my 70 GMC, one in the long step parts 70 GMC, and one in the Longhorn 70 GMC parts truck. All leaf spring however, but I have looked at coil spring 60's in Chevys. The Longhorn has 40" spring centers just like the 4x4, so I plan on swapping that one into my Jimmy with the 4.10 gears from the longstep.
06-13-2003, 04:36 PM | #10 |
Some of the new ones have deflection screws that keep the carrier from flexing under high loads (hint hint). They also yield more options when it comes to brakes and other accessories - plus they don't have the saddles welded on so you can put them in leaf or coil spring suspensions. They also look cool as hell...
Just something I've been dreaming about...
06-13-2003, 10:29 PM | #11 |
I don't think I have ever seen a failure on a bearing cap on a 60. Regardless of the power. And I have seen plenty of 8 second drag cars with 60's. You can always add an aluminum cover that has the cap reinforcing bolts in it.
I just built a Chevelle 12 bolt and installed a Tom's steel cap on the drivers side. IMO, it weaked the casting and I would have used the stock cap with the girdle cover. I built my own rear for my 68 Camaro convertible. It started out as a 65 Impala housing with all of the coil spring trailing arm brackets. The cutting torch and grinder made quick work of that! It is narrowed to the stock Camaro width and the big car ends allow the Corvette caliper brackets to be bolted to it. No reason to buy new! It has Mopar housing leaf spring mounts on it in the pic, but I have since cut them off and replaced them with repop Camaro multi-leaf mounts. Save your money and get you a bolt in 60 from a 67-72!
06-14-2003, 12:47 AM | #12 |
For whatever its worth. .....Another option would be to go with an overdrive tranny and leave the rear end alone.
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
06-14-2003, 01:03 AM | #13 |
"Ochre Ogre"
Your panhard bar is different and has different frame mounts from 12 bolt to Dana 60 to Eaton/Corp. I do have a spare Dana 60, coil mount with 3.54 gears. It isn't going to be cheap because it is posi. California to Michigan via Minnesota??
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
